Octolapse first layer fail
Greetings All,
Printer: Ender3 S1Pro
Slicer: Orca
OS/Octoprint: Mint Linux running on a repurposed Mac Mini 2011
Webcam: Logitech C922 Pro
Layer Height: 0.16
I installed and configured Octolapse using the instructions and slicer settings. For slicer I selected other, and there really isn't much to fill out.
When Octolapse is enabled, the first layer barely prints. It is more of a blob or barely extruded streaks of filament. When I disable the plugin, everything works just fine.
I have searched everywhere before posting and looked at YouTube videos, but all of them are using Cura, noting for Orca.
Anyone know what the issue could be or recommend another direction?
Thanks for the help.
I will bet that you are in Dry Run/Test Mode - this prevents all Extrusion events and you are just drooling filament. Check in OctoLapse tab.
Thanks, I wish it was that easy, but that's not it.
I went back to TimeLapse+ for the time being until hopefully I can figure it out unless there are other suggestions to try.
I have the same problem any fixes I would like to use octolapse
