I'm trying to install Octolaspse with no luch. I don't get an error message. It completes the install and then says Installed Uknown. I've tried installing from plugin manager, url, and ssh to no avail.
- Install and attempt to uninstall other plugins
- Restart OctoPrint
- Restart OctoPi
- Reflash SD card with OctoPi image
Complete Logs
- Here is the relevent lines from octoprint.log. The complete logs have been attached.
2020-11-06 09:47:45,286 - octoprint.plugins.pluginmanager - INFO - Installing plugin from https://github.com/FormerLurker/Octolapse/archive/v0.4.0.zip
2020-11-06 09:47:46,218 - octoprint.plugin.core - ERROR - Error loading plugin octolapse
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 972, in _import_plugin
module = _load_module(module_name, spec)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 71, in _load_module
return imp.load_module(name, f, filename, details)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse/__init__.py", line 29, in <module>
import octoprint_octolapse.log as log
AttributeError: 'module' object has no attribute 'log'
2020-11-06 09:50:12,681 - octoprint.plugin.core - ERROR - Error loading plugin octolapse
2020-11-06 09:50:12,856 - octoprint.plugins.pluginmanager - WARNING - The plugin was installed successfully, but couldn't be found afterwards to initialize properly during runtime. Please restart OctoPrint.
2020-11-06 09:50:12,861 - octoprint.util - WARNING - Could not delete temporary directory /tmp/tmpBEzEA7: [Errno 21] Is a directory: '/tmp/tmpBEzEA7'
- Here is the plugin_pluginmanager_console.log
2020-11-06 09:22:22,935 /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install file:///tmp/tmpQKvdik/Octolapse-0.4.0.zip --no-cache-dir
2020-11-06 09:22:25,195 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2020-11-06 09:22:25,195 > Processing /tmp/tmpQKvdik/Octolapse-0.4.0.zip
2020-11-06 09:22:32,650 > Requirement already satisfied: pillow>=6.2.0<7.0.0 in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (6.2.2)
2020-11-06 09:22:32,651 > Requirement already satisfied: sarge in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (0.1.5.post0)
2020-11-06 09:22:32,651 > Requirement already satisfied: six in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (1.12.0)
2020-11-06 09:22:32,652 > Requirement already satisfied: OctoPrint>1.3.8 in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (1.4.2)
2020-11-06 09:22:32,652 > Requirement already satisfied: psutil in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (5.7.3)
2020-11-06 09:22:32,652 > Requirement already satisfied: file_read_backwards in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (2.0.0)
2020-11-06 09:22:32,653 > Requirement already satisfied: setuptools>=6.0 in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (41.5.1)
2020-11-06 09:22:32,654 > Requirement already satisfied: awesome-slugify<1.7,>=1.6.5 in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (1.6.5)
2020-11-06 09:22:32,654 > Requirement already satisfied: futures<4,>=3.3; python_version < "3" in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (3.3.0)
2020-11-06 09:22:32,655 > Requirement already satisfied: semantic-version<3,>=2.8.5 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2.8.5)
2020-11-06 09:22:32,655 > Requirement already satisfied: itsdangerous<2,>=1.1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.1.0)
2020-11-06 09:22:32,655 > Requirement already satisfied: future<1,>=0.18.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.18.2)
2020-11-06 09:22:32,656 > Requirement already satisfied: blinker<2,>=1.4 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.4)
2020-11-06 09:22:32,656 > Requirement already satisfied: unidecode<0.05,>=0.04.14 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.4.21)
2020-11-06 09:22:32,657 > Requirement already satisfied: Flask-Assets<3,>=2.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2.0)
2020-11-06 09:22:32,657 > Requirement already satisfied: PyYAML<6,>=5.3.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (5.3.1)
2020-11-06 09:22:32,657 > Requirement already satisfied: pylru<2,>=1.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.2.0)
2020-11-06 09:22:32,658 > Requirement already satisfied: pyserial<4,>=3.4 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (3.4)
2020-11-06 09:22:32,658 > Requirement already satisfied: pkginfo<2,>=1.5.0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.5.0.1)
2020-11-06 09:22:32,658 > Requirement already satisfied: wrapt<2,>=1.12.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.12.1)
2020-11-06 09:22:32,659 > Requirement already satisfied: chainmap<2,>=1.0.3; python_version < "3" in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.0.3)
2020-11-06 09:22:32,659 > Requirement already satisfied: Click<8,>=7.1.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (7.1.2)
2020-11-06 09:22:32,660 > Requirement already satisfied: markupsafe<2.0,>=1.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.1.1)
2020-11-06 09:22:32,660 > Requirement already satisfied: markdown<3.2,>=3.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (3.1.1)
2020-11-06 09:22:32,660 > Requirement already satisfied: watchdog<1,>=0.10.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.10.3)
2020-11-06 09:22:32,661 > Requirement already satisfied: netifaces<1,>=0.10.9 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.10.9)
2020-11-06 09:22:32,661 > Requirement already satisfied: scandir<2,>=1.10; python_version < "3" in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.10.0)
2020-11-06 09:22:32,662 > Requirement already satisfied: rsa==4.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (4.0)
2020-11-06 09:22:32,662 > Requirement already satisfied: filetype<2,>=1.0.7 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.0.7)
2020-11-06 09:22:32,663 > Requirement already satisfied: tornado==5.1.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (5.1.1)
2020-11-06 09:22:32,663 > Requirement already satisfied: cachelib<1,>=0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.1)
2020-11-06 09:22:32,663 > Requirement already satisfied: werkzeug<2,>=1.0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.0.1)
2020-11-06 09:22:32,664 > Requirement already satisfied: typing<4,>=3.7.4.1; python_version < "3" in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (3.7.4.1)
2020-11-06 09:22:32,664 > Requirement already satisfied: regex!=2018.11.6 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2019.8.19)
2020-11-06 09:22:32,665 > Requirement already satisfied: flask<2,>=1.1.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.1.2)
2020-11-06 09:22:32,665 > Requirement already satisfied: sentry-sdk<1,>=0.15.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.19.2)
2020-11-06 09:22:32,665 > Requirement already satisfied: OctoPrint-FirmwareCheck>=2020.06.22 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2020.9.23)
2020-11-06 09:22:32,666 > Requirement already satisfied: feedparser<6,>=5.2.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (5.2.1)
2020-11-06 09:22:32,666 > Requirement already satisfied: OctoPrint-FileCheck>=2020.07.06 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2020.8.7)
2020-11-06 09:22:32,667 > Requirement already satisfied: netaddr<1,>=0.7.19 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.7.19)
2020-11-06 09:22:32,667 > Requirement already satisfied: Jinja2<3,>=2.11.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2.11.2)
2020-11-06 09:22:32,668 > Requirement already satisfied: Flask-Login<0.6,>=0.5 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.5.0)
2020-11-06 09:22:32,668 > Requirement already satisfied: emoji<1,>=0.5.4 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.5.4)
2020-11-06 09:22:32,669 > Requirement already satisfied: requests<3,>=2.23.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2.24.0)
2020-11-06 09:22:32,669 > Requirement already satisfied: Flask-Babel<2,>=1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.0.0)
2020-11-06 09:22:32,670 > Requirement already satisfied: frozendict<2,>=1.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.2)
2020-11-06 09:22:32,670 > Requirement already satisfied: websocket-client<1,>=0.57 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.57.0)
2020-11-06 09:22:32,670 > Requirement already satisfied: monotonic<2,>=1.5; python_version < "3" in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.5)
2020-11-06 09:22:32,671 > Requirement already satisfied: webassets>=2.0 in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Assets<3,>=2.0->OctoPrint>1.3.8->Octolapse==0.4.0) (2.0)
2020-11-06 09:22:32,671 > Requirement already satisfied: pathtools>=0.1.1 in /home/pi/oprint/lib/python2.7/site-packages (from watchdog<1,>=0.10.2->OctoPrint>1.3.8->Octolapse==0.4.0) (0.1.2)
2020-11-06 09:22:32,672 > Requirement already satisfied: pyasn1>=0.1.3 in /home/pi/oprint/lib/python2.7/site-packages (from rsa==4.0->OctoPrint>1.3.8->Octolapse==0.4.0) (0.4.7)
2020-11-06 09:22:32,673 > Requirement already satisfied: singledispatch in /home/pi/oprint/lib/python2.7/site-packages (from tornado==5.1.1->OctoPrint>1.3.8->Octolapse==0.4.0) (3.4.0.3)
2020-11-06 09:22:32,673 > Requirement already satisfied: backports-abc>=0.4 in /home/pi/oprint/lib/python2.7/site-packages (from tornado==5.1.1->OctoPrint>1.3.8->Octolapse==0.4.0) (0.5)
2020-11-06 09:22:32,674 > Requirement already satisfied: certifi in /home/pi/oprint/lib/python2.7/site-packages (from sentry-sdk<1,>=0.15.1->OctoPrint>1.3.8->Octolapse==0.4.0) (2019.9.11)
2020-11-06 09:22:32,674 > Requirement already satisfied: urllib3>=1.10.0 in /home/pi/oprint/lib/python2.7/site-packages (from sentry-sdk<1,>=0.15.1->OctoPrint>1.3.8->Octolapse==0.4.0) (1.25.6)
2020-11-06 09:22:32,675 > Requirement already satisfied: chardet<4,>=3.0.2 in /home/pi/oprint/lib/python2.7/site-packages (from requests<3,>=2.23.0->OctoPrint>1.3.8->Octolapse==0.4.0) (3.0.4)
2020-11-06 09:22:32,675 > Requirement already satisfied: idna<3,>=2.5 in /home/pi/oprint/lib/python2.7/site-packages (from requests<3,>=2.23.0->OctoPrint>1.3.8->Octolapse==0.4.0) (2.8)
2020-11-06 09:22:32,676 > Requirement already satisfied: Babel>=2.3 in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Babel<2,>=1.0->OctoPrint>1.3.8->Octolapse==0.4.0) (2.7.0)
2020-11-06 09:22:32,676 > Requirement already satisfied: pytz in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Babel<2,>=1.0->OctoPrint>1.3.8->Octolapse==0.4.0) (2019.3)
2020-11-06 09:22:32,677 > Building wheels for collected packages: Octolapse
2020-11-06 09:22:32,677 > Building wheel for Octolapse (setup.py): started
2020-11-06 09:23:34,727 > Building wheel for Octolapse (setup.py): still running...
2020-11-06 09:24:37,782 > Building wheel for Octolapse (setup.py): still running...
2020-11-06 09:25:06,807 > Building wheel for Octolapse (setup.py): finished with status 'done'
2020-11-06 09:25:06,807 > Created wheel for Octolapse: filename=Octolapse-0.4.0-cp27-cp27mu-linux_armv7l.whl size=3286491 sha256=516bb9f0f0ae17757524819cb9c054859977b45d0b2e6501122dd9291d287546
2020-11-06 09:25:06,808 > Stored in directory: /tmp/pip-ephem-wheel-cache-JkkROX/wheels/a1/2e/71/0052d742f2ef415bb64495fba276d2a8adfe7e2ec237052bde
2020-11-06 09:25:06,808 > Successfully built Octolapse
2020-11-06 09:25:08,226 > Installing collected packages: Octolapse
2020-11-06 09:25:08,226 > Attempting uninstall: Octolapse
2020-11-06 09:25:08,227 > Found existing installation: Octolapse 0.4.0
2020-11-06 09:25:08,227 > Uninstalling Octolapse-0.4.0:
2020-11-06 09:25:10,231 > Successfully uninstalled Octolapse-0.4.0
2020-11-06 09:25:11,735 > Successfully installed Octolapse-0.4.0
2020-11-06 09:37:39,575 /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check uninstall --yes TheSpaghettiDetective
2020-11-06 09:37:42,168 > Found existing installation: TheSpaghettiDetective 1.4.3
2020-11-06 09:37:42,169 > Uninstalling TheSpaghettiDetective-1.4.3:
2020-11-06 09:37:42,170 > Successfully uninstalled TheSpaghettiDetective-1.4.3
2020-11-06 09:37:42,829 > Cleaning up plugin thespaghettidetective...
2020-11-06 09:47:46,401 /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install file:///tmp/tmpBEzEA7/Octolapse-0.4.0.zip --no-cache-dir
2020-11-06 09:47:48,650 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2020-11-06 09:47:48,651 > Processing /tmp/tmpBEzEA7/Octolapse-0.4.0.zip
2020-11-06 09:47:53,646 > Requirement already satisfied: pillow>=6.2.0<7.0.0 in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (6.2.2)
2020-11-06 09:47:53,647 > Requirement already satisfied: sarge in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (0.1.5.post0)
2020-11-06 09:47:53,647 > Requirement already satisfied: six in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (1.12.0)
2020-11-06 09:47:53,648 > Requirement already satisfied: OctoPrint>1.3.8 in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (1.4.2)
2020-11-06 09:47:53,648 > Requirement already satisfied: psutil in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (5.7.3)
2020-11-06 09:47:53,648 > Requirement already satisfied: file_read_backwards in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (2.0.0)
2020-11-06 09:47:53,649 > Requirement already satisfied: setuptools>=6.0 in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (41.5.1)
2020-11-06 09:47:53,649 > Requirement already satisfied: awesome-slugify<1.7,>=1.6.5 in /home/pi/oprint/lib/python2.7/site-packages (from Octolapse==0.4.0) (1.6.5)
2020-11-06 09:47:53,649 > Requirement already satisfied: futures<4,>=3.3; python_version < "3" in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (3.3.0)
2020-11-06 09:47:53,650 > Requirement already satisfied: semantic-version<3,>=2.8.5 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2.8.5)
2020-11-06 09:47:53,650 > Requirement already satisfied: itsdangerous<2,>=1.1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.1.0)
2020-11-06 09:47:53,650 > Requirement already satisfied: future<1,>=0.18.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.18.2)
2020-11-06 09:47:53,651 > Requirement already satisfied: blinker<2,>=1.4 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.4)
2020-11-06 09:47:53,651 > Requirement already satisfied: unidecode<0.05,>=0.04.14 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.4.21)
2020-11-06 09:47:53,652 > Requirement already satisfied: Flask-Assets<3,>=2.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2.0)
2020-11-06 09:47:53,652 > Requirement already satisfied: PyYAML<6,>=5.3.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (5.3.1)
2020-11-06 09:47:53,652 > Requirement already satisfied: pylru<2,>=1.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.2.0)
2020-11-06 09:47:53,653 > Requirement already satisfied: pyserial<4,>=3.4 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (3.4)
2020-11-06 09:47:53,653 > Requirement already satisfied: pkginfo<2,>=1.5.0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.5.0.1)
2020-11-06 09:47:53,653 > Requirement already satisfied: wrapt<2,>=1.12.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.12.1)
2020-11-06 09:47:53,654 > Requirement already satisfied: chainmap<2,>=1.0.3; python_version < "3" in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.0.3)
2020-11-06 09:47:53,654 > Requirement already satisfied: Click<8,>=7.1.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (7.1.2)
2020-11-06 09:47:53,654 > Requirement already satisfied: markupsafe<2.0,>=1.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.1.1)
2020-11-06 09:47:53,655 > Requirement already satisfied: markdown<3.2,>=3.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (3.1.1)
2020-11-06 09:47:53,655 > Requirement already satisfied: watchdog<1,>=0.10.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.10.3)
2020-11-06 09:47:53,656 > Requirement already satisfied: netifaces<1,>=0.10.9 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.10.9)
2020-11-06 09:47:53,656 > Requirement already satisfied: scandir<2,>=1.10; python_version < "3" in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.10.0)
2020-11-06 09:47:53,656 > Requirement already satisfied: rsa==4.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (4.0)
2020-11-06 09:47:53,656 > Requirement already satisfied: filetype<2,>=1.0.7 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.0.7)
2020-11-06 09:47:53,657 > Requirement already satisfied: tornado==5.1.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (5.1.1)
2020-11-06 09:47:53,657 > Requirement already satisfied: cachelib<1,>=0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.1)
2020-11-06 09:47:53,657 > Requirement already satisfied: werkzeug<2,>=1.0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.0.1)
2020-11-06 09:47:53,658 > Requirement already satisfied: typing<4,>=3.7.4.1; python_version < "3" in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (3.7.4.1)
2020-11-06 09:47:53,658 > Requirement already satisfied: regex!=2018.11.6 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2019.8.19)
2020-11-06 09:47:53,659 > Requirement already satisfied: flask<2,>=1.1.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.1.2)
2020-11-06 09:47:53,659 > Requirement already satisfied: sentry-sdk<1,>=0.15.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.19.2)
2020-11-06 09:47:53,659 > Requirement already satisfied: OctoPrint-FirmwareCheck>=2020.06.22 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2020.9.23)
2020-11-06 09:47:53,659 > Requirement already satisfied: feedparser<6,>=5.2.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (5.2.1)
2020-11-06 09:47:53,660 > Requirement already satisfied: OctoPrint-FileCheck>=2020.07.06 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2020.8.7)
2020-11-06 09:47:53,660 > Requirement already satisfied: netaddr<1,>=0.7.19 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.7.19)
2020-11-06 09:47:53,660 > Requirement already satisfied: Jinja2<3,>=2.11.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2.11.2)
2020-11-06 09:47:53,660 > Requirement already satisfied: Flask-Login<0.6,>=0.5 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.5.0)
2020-11-06 09:47:53,661 > Requirement already satisfied: emoji<1,>=0.5.4 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.5.4)
2020-11-06 09:47:53,661 > Requirement already satisfied: requests<3,>=2.23.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (2.24.0)
2020-11-06 09:47:53,661 > Requirement already satisfied: Flask-Babel<2,>=1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.0.0)
2020-11-06 09:47:53,661 > Requirement already satisfied: frozendict<2,>=1.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.2)
2020-11-06 09:47:53,662 > Requirement already satisfied: websocket-client<1,>=0.57 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (0.57.0)
2020-11-06 09:47:53,662 > Requirement already satisfied: monotonic<2,>=1.5; python_version < "3" in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint>1.3.8->Octolapse==0.4.0) (1.5)
2020-11-06 09:47:53,662 > Requirement already satisfied: webassets>=2.0 in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Assets<3,>=2.0->OctoPrint>1.3.8->Octolapse==0.4.0) (2.0)
2020-11-06 09:47:53,663 > Requirement already satisfied: pathtools>=0.1.1 in /home/pi/oprint/lib/python2.7/site-packages (from watchdog<1,>=0.10.2->OctoPrint>1.3.8->Octolapse==0.4.0) (0.1.2)
2020-11-06 09:47:53,663 > Requirement already satisfied: pyasn1>=0.1.3 in /home/pi/oprint/lib/python2.7/site-packages (from rsa==4.0->OctoPrint>1.3.8->Octolapse==0.4.0) (0.4.7)
2020-11-06 09:47:53,663 > Requirement already satisfied: singledispatch in /home/pi/oprint/lib/python2.7/site-packages (from tornado==5.1.1->OctoPrint>1.3.8->Octolapse==0.4.0) (3.4.0.3)
2020-11-06 09:47:53,664 > Requirement already satisfied: backports-abc>=0.4 in /home/pi/oprint/lib/python2.7/site-packages (from tornado==5.1.1->OctoPrint>1.3.8->Octolapse==0.4.0) (0.5)
2020-11-06 09:47:53,664 > Requirement already satisfied: certifi in /home/pi/oprint/lib/python2.7/site-packages (from sentry-sdk<1,>=0.15.1->OctoPrint>1.3.8->Octolapse==0.4.0) (2019.9.11)
2020-11-06 09:47:53,664 > Requirement already satisfied: urllib3>=1.10.0 in /home/pi/oprint/lib/python2.7/site-packages (from sentry-sdk<1,>=0.15.1->OctoPrint>1.3.8->Octolapse==0.4.0) (1.25.6)
2020-11-06 09:47:53,664 > Requirement already satisfied: chardet<4,>=3.0.2 in /home/pi/oprint/lib/python2.7/site-packages (from requests<3,>=2.23.0->OctoPrint>1.3.8->Octolapse==0.4.0) (3.0.4)
2020-11-06 09:47:53,665 > Requirement already satisfied: idna<3,>=2.5 in /home/pi/oprint/lib/python2.7/site-packages (from requests<3,>=2.23.0->OctoPrint>1.3.8->Octolapse==0.4.0) (2.8)
2020-11-06 09:47:53,665 > Requirement already satisfied: Babel>=2.3 in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Babel<2,>=1.0->OctoPrint>1.3.8->Octolapse==0.4.0) (2.7.0)
2020-11-06 09:47:53,665 > Requirement already satisfied: pytz in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Babel<2,>=1.0->OctoPrint>1.3.8->Octolapse==0.4.0) (2019.3)
2020-11-06 09:47:53,666 > Building wheels for collected packages: Octolapse
2020-11-06 09:47:53,666 > Building wheel for Octolapse (setup.py): started
2020-11-06 09:49:14,096 > Building wheel for Octolapse (setup.py): still running...
2020-11-06 09:50:09,732 > Building wheel for Octolapse (setup.py): finished with status 'done'
2020-11-06 09:50:09,733 > Created wheel for Octolapse: filename=Octolapse-0.4.0-cp27-cp27mu-linux_armv7l.whl size=3286411 sha256=0549a67304e68019419a80e219cc6cb65aac02004be468059b70c6a85e4c7d68
2020-11-06 09:50:09,733 > Stored in directory: /tmp/pip-ephem-wheel-cache-uEUDcX/wheels/3f/8c/b5/56c6556b91cb00e86559c6240016e8c4738417dd162a26757d
2020-11-06 09:50:09,733 > Successfully built Octolapse
2020-11-06 09:50:09,734 > Installing collected packages: Octolapse
2020-11-06 09:50:09,734 > Attempting uninstall: Octolapse
2020-11-06 09:50:09,735 > Found existing installation: Octolapse 0.4.0
2020-11-06 09:50:09,735 > Uninstalling Octolapse-0.4.0:
2020-11-06 09:50:09,735 > Successfully uninstalled Octolapse-0.4.0
2020-11-06 09:50:11,739 > Successfully installed Octolapse-0.4.0
- Version 0.17.0
- Raspberry pi 3 B+
- pi camera module v2
- Prusa i3 mk3s
- Google Chrome
- Windows
