I'm using Octolapse for timelapses with an Ender 3 Pro and having generally great results, but I'm getting a lot of stringing artifacts where the nozzle jumps away to pose for a snapshot. I'm using the "back left" setting.
I understand a certain amount is unavoidable, but I've noticed that it's only the Octolapse snapshot jumpoff point where I'm getting these artifacts. This suggests that retraction and travel is working fine elsewhere in the print.
For example, here's a print with two identical parts:
The nearer part is perfect, while the farther one has a bunch of stringy stuff where the nozzle jumps off. But only where it jumps off for the snapshot; there's no stringy stuff between the two parts at all, even though the nozzle has to travel back and forth there at least once each layer.
I'm slicing with Cura 4.9.0 and having Octolapse import the settings automatically (using the gcode start script by tjjfvi that Octolapse suggests). When I switch "Slicer Type" from "Automatic Configuration" to "Cura V4.2 and Above", all the settings look correct (as set in Cura). So I think it's working.
I would expect that if the retraction settings are working well for the rest of the print, they would work for Octolapse too. So either that's not the case (due to something different about the way Octolapse moves) or it is the case, but Octolapse isn't actually using those settings for some reason.
Is anyone else having a similar issue? How can I further diagnose and mitigate this?
Thanks.
