Hello all, I just got octolapse today and was trying to set it up. When in the add new profile menu, after selecting my printer (ender 3 pro) and automatic slicer configuration, hitting the save button seems to do nothing. No error shows up or anything but this shows up in the logs:
2020-09-13 08:59:51,986 - octolapse.init - ERROR - An error occurred in import_settings_request.
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse/init.py", line 942, in import_settings
self.available_profiles
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse/settings.py", line 2462, in import_settings_from_file
available_server_profiles, update_existing=update_existing
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse/settings.py", line 2499, in import_settings_from_text
plugin_version, settings, default_settings_folder, data_directory
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse/migration.py", line 85, in migrate_settings
raise Exception("Could not find version information within the settings json, cannot perform migration.")
Exception: Could not find version information within the settings json, cannot perform migration.
So instead of loading the file from the server, I went to the github to download the profile settings directly from this page: https://github.com/FormerLurker/Octolapse-Profiles and upload them through octolapse settings>printer>import settings and get this error:
Unable To Import Settings
Unable to import the provided settings, see plugin_octolapse.log for more information.
In the log file this comes up:
Something that may be at the root of this is towards the beginning of the log file. Before I tried changing the profile a few more times.
ExternalSettingsError: profiles-retrieval-error: An error occurred while retrieving profiles from the server. - Inner Exception: HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /FormerLurker/Octolapse-Profiles/master/versions.json?nonce=0ec0aec12928497d839ddce399473e36 (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb07486d0>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
Unsure if this is a problem on my end or on the github repository's end.
Any help is greatly appreciated, Thank you all!
Here is the log file:
plugin_octolapse (1).log (8.5 KB)
