OctoPi Release Candidate 0.16.0rc1 needs testers!
Guy Sheffer just published a release candidate for the next release of the OctoPi image, version 0.16.0.
Apart from adding support for the Pi 3A+ and of course shipping with the current stable OctoPrint version 1.3.10, 0.16.0rc1 also contains the following changes:
Changes in the image
  • Raspberrypi 3A+ support
  • linux kernel 4.14.79-v7+ from new base image 2018-11-13-octopi-stretch-lite
  • OctoPrint 1.3.10
  • Bug fixes
Build notes
  • Uses CustomPiOS 1.1.0
  • Our nightly/release builds have moved to the new Docker build supported in CustomPiOS 1.1.0. You can still use the vagrant build method.
If you’ve been waiting for a new OctoPi release, this is your chance to give the candidate a test drive and report any findings back in the ticket on the OctoPi repository so we can make sure the release is solid!
You can find the download links in the ticket.
Confused about the difference between OctoPi and OctoPrint? Read this!
This is a companion discussion topic for the original entry at https://octoprint.org/blog/2019/01/25/octopi-release-candidate-0-16-0rc1/
