Hi is there any instructions to run both in the same raspberry?
I have a raspberry with hassio installation as image.
Can i run octroprint also? Not the plugin.
Iirc hassio runs in a docker container so it should be no problem to install octopi.
Go with the raspberry guide
Edit:
If hassio uses port 80 for the webinterface you might want to choose another port for octoprint or skip the proxy part so it runs on port 5000.
That being said - get one raspberry pi for each. I run HA myself, I used to run it on a Pi and it bogged down the poor fellow pretty hard once I set up some things. You DON'T want a bogged down Pi when you also want it to stream a job as fast as possible to your printer, that's just a recipe for tears.
What I don't know is how to get them both onto the same pi .
At what I'm saying is that you really shouldn't run them on the same pi anyhow.
You will run into trouble. It won't work well. Get a second pi.
I started with the octopi image. Then installed docker-ce. Then installed HASSIO. HASSIO uses port 8123 and octoprint uses 80 so that's all good.
