Equipment: Creality Ender 3 Pro
Raspberry Pi 3 b+
Octoprint Version: 1.4.2,
NO Gcode scripts running
Just added octopi to my ender 3 for the first time via Rasp Pi 3 b+ and Pi cam V2. All hardware and software runs/loads without issue.
PROBLEM: If I load a gcode file through octoprint everything starts fine...printer head / bed heat up normally, but once the actual print starts, the print head will move approximately 10mm above the print surface and will then attempt to print. If I do NOT initially use octoprint but rather use the sd card slot of the ender 3, this problem does not exist.
However, If I first print from ocotoprint and the issue occurs, the same problem will occur if I attempt to print on the ender 3 from sd card, unless I first auto home and then save the offsets and then start my print job again. Meaning, as long as I do not attempt to print from ocotprint first, the ender 3 prints just fine if I print directly from its own SD card and I do not use octoprint first.
To attempt to solve, I have checked to ensure my printer profile in octoprint is correct and bed size settings are correct. I have tried different gcode files and the same problem occurs. This issue does NOT occur if I print directly from Ender 3 SD card without using octoprint first.
Z-offest is being altered at start of print
Checked settings
NO
Complete Logs
I don't yet know how to add those.
1.4.2octoprint.log.zip (4.5 KB)
