Octoprint multiple instances
Hello i run two printers on one rasspbery pi3b a make two instances expampe one is 192.168.1.30 and second 192.168.1.30:5001, i forgot name and passpword for second instance octoprint, how reset name/password on second instance, when i try i reset only first .
i make it from this video:
can you still log in to the pi via ssh or console? are you following this? - I forgot my OctoPrint password, how can I reset it?
Yes i log via putty normaly and i follow this guide it works but reset password only on first instance for printer 1. second istance still want password.
Try this and change the paths accordingly.
i had no idea how
