I have Octoprint running on Raspberry Pi and plan to add a Hyperpixel 4 Touch display. I want to add LED strip, PWM fan and temperature sensor to implement a smart enclosure. As Hyperpixel will be using all the GPIO ports, do you have any recommendations on implementing such a setup?
Was planning to use the OctoEnclosure plugin but it is only design for GPIO integration.
