Octoprint/RPi seems to freeze when using NVME
I know it is overkill, using a RPi 5 with NVME, but I had it lying around, so I started using it.
Not much of a speed advantage, except for sending GCODE files, they appear a lot quicker in the file list.
But I do have another weird issue.
OctoPrint/RPi seems to randomly freeze (sometimes multiple times a day, sometimes after 3 days) when using an NVME drive with an Argon Neo 5 M.2 case with a compatible NVME drive.
To rule out anything else, I cloned the NVME to a USB drive and that has been working just fine for over 2 weeks now.
Also checked loads for CPU, RAM, Swap, storage, thermals, etc, but nothing stood out. It happened a couple of times during a print, but it also happens when it is sitting idle for hours/days.
The freeze also disconnects from wired network, so unable to remote in, but when I connected a display, it just showed a login prompt on screen when it froze. But it didn't respond to any key-presses.
Also replaced the power adapter for a beefier one, no difference, and the RPi doesn't ever report power issues.
Use the same setup for multiple RPi's running all sort of tasks, like Home Assistant at multiple locations, etc and they don't seem to have this issue.
Could be a faulty hat of course, but I would expect some sort of storage issue before it freezes.
Anyone else experience something like this or know how to troubleshoot this.
If you cloned the NVME drive to USB and it doesn't freeze with the USB, then I would say you have an issue with the NVME drive itself.
Can you get the system log files?? I believe this is down at the system level. Not the Octoprint files.
That's also what I thought, but Argon says it is the Raspberry Pi, which is unlikely.
Will try that, it just froze again, after placing back the NVME yesterday and updating all drivers and firmware. No change obviously.
Will attach a monitor, so I can see what happens next time and hopefully can retrieve the logfiles.
I managed to grab a photo of the screen after it froze. The RPi didn't respond to any input anymore through the keyboard.
Not sure what to make of this.
Have you forced the PCI Express speed to 3? If so, you might try putting it back to 2.
Forcing PCI Express Gen 3.0 speeds on the Pi 5
Yes, I was using PCI Express speed 3. Have set it back to 2. Now we wait and see :wink:
Seems like speed 3 was the issue. Has been running just fine for 2 weeks. No issues at all.
Thanks for the tip!
