I recently got octoprint added to my setup. I have an i3 mk3s+ with an MMU2s, and I’m using a raspberry pi zero 2 for octoprint. I let a print go on its own to test the timelapse feature using the octolapse plugin, and when I came back the print had failed. The printer was continuing like it was printing, but the end of the filament was several centimeters from the hot end. I verified that the filament sensor is reading correctly. Any idea what happened here?
What firmware version is your Prusa running? From what I can gather from a quick search, 3.10+ have host action commands, however, they might not be sending the //action:pause command for filament runout, just for pressing the actions on the display... For OctoPrint to pause the print, it needs to be told to do so - it's not magic. So if there is no information sent out by the printer then there will be no pause.
