OctoPrint-Twilio (smsnotifier) errors after 1.4.0 update
After updating OctoPrint to 1.4.0, the SMS Notifier plugin fails.
Reboot the server.
Logs
I can provide more, but this seems to be the relevant parts of the logs.
Before the update:
2020-03-10 03:27:56,167 - octoprint.server - INFO - OctoPrint 1.3.12
2020-03-10 03:27:56,190 - octoprint.plugin.core - INFO - 18 plugin(s) registered with the system:
|  Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
|  python:
|    pip: 19.3.1
|    version: 2.7.16
2020-03-10 22:00:49,021 - octoprint.printer.standard.job - INFO - Print job done - origin: local, path: monsterHP_tray_0.2mm_PLA_MK3S_2h59m.gcode, owner: egburr
2020-03-10 22:00:49,224 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
2020-03-10 22:00:51,252 - octoprint.plugins.tracking - INFO - Sent tracking event print_done, payload: {'origin': 'local', 'file': 'c9f8039062370471f012bd9b8a6dd87a05618acc', 'elapsed': 10784}
2020-03-10 22:00:53,149 - octoprint.plugins.smsnotifier - INFO - Print notification sent to +1XXXXXXXXXX
After the update:
2020-03-12 00:35:57,733 - octoprint.server - INFO - OctoPrint 1.4.0
2020-03-12 00:35:57,754 - octoprint.plugin.core - INFO - 18 plugin(s) registered with the system:
|  python:
|      pip: 19.3.1
|      version: 2.7.16
2020-03-12 20:57:35,246 - octoprint.printer.standard.job - INFO - Print job done - origin: local, path: equipment_lid_0.2mm_PLA_MK3S_2h34m.gcode, owner: egburr
2020-03-12 20:57:35,408 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
2020-03-12 20:57:36,763 - octoprint.plugins.tracking - INFO - Sent tracking event print_done, payload: {'origin': u'local', 'file': '532dbb377e1da30167b8740fba4ef38c1df74e52', u'elapsed': 9493}
2020-03-12 20:57:37,165 - octoprint.plugin - ERROR - Error while calling plugin smsnotifier
  File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/__init__.py", line 224, in call_plugin
  File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_smsnotifier/__init__.py", line 90, in on_event
    return self._send_txt(payload)
  File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_smsnotifier/__init__.py", line 94, in _send_txt
    filename = os.path.basename(payload["file"])
KeyError: 'file'
2020-03-12 21:05:58,498 - octoprint.server.heartbeat - INFO - Server heartbeat <3
Before 1.4.0 update:
After 1.4.0 update:
Notice the "u" in the local and elapsed keys, but not in the file key? But the error seems to be complaining about the file key. And this is what the server is sending to the plug-in if I understand it correctly.
Unfortunately, I don't know python, so don't know what this means, but it's an obvious before/after difference I can see.
Printer: Prusa i3 MK3S
Firmware: 3.8.1
OctoPrint 1.3.12 ==> 1.4.0
SMS Notifier 0.3.2
(I've submitted a issue in the github project for it, but there has been no activity there for 2 years, so I have no idea what status is.)
Any thoughts on this?
Thanks!
Have you tried uninstalling the plugin and reinstalling it?
See my reply on the plugin's issue tracker and the related ticket there:
tldr: the plugin uses an event payload field that has been deprecated for over three years, it needs to be updated.
Thanks for the update. I appreciate your taking the time to look at and respond to this.
