Thanks for informations. I will wait before buy SKR 1.3, I print between 40/60mm/s too so ....
Maybe if I found the board at a good price
Davy
Davy
Hey I'm running into the problem with the TFT and octoprint. I had it all working with my MKS Gen v.14 but decided to build a nice enclosure with a 7in touch screen my TFT32 and my 12864 stock ender display. I have some relays and PWM modules on my GPIO pins of my pi 3. Running the enclosure plugin that all works great. But when I installed my new SKR v1.3 the serial port was on 0. So I set the serial port _ 2 on -1 . Octoprint will work on -1 and so will the TFT. But I'm getting a communication error and it disconnects from the printer. Hoping someone can tell me how to get octoprint to work correct. But I believe since they are bumping heads it's causing my printer to act up. I'm getting bad skipping only on the Y axis. Every couple minutes. Just don't know what to do here. Hoping someone can help me out.
Is the baud rate for the screen set the same as the board?
have also blobs but fix it now.
I have my rapsberry pi booting with usb not sd card.
and i have also a hp webcam on it and the mks gen l board.
I think the usb power of the original raspberry pi power plug it's to low.
I remove the webcam and problems are gone.
