OctoScreen restarts every ~6 minutes (Watchdog timeout)
While printing, my OctoScreen restarts every ~6 minutes.
The time elapsed/remaining slows down, and eventually becomes unresponsive and reboots
Always occurring, even after reboot.
System logs show reboot occurs due to Watchdog timeout.
System Info:
OctoPrint v1.6.1
OctoScreen 2.7.1
OctoScreen plugin 2.6.0
Waveshare 4.3inch DSI LCD
Resoluton: 800x480
Raspberry Pi 4 4GB
Prusa MK3S
Additional Info:
-RPi is sufficiently powered
-Only OctoScreen is reseting, OctopPrint logs show no indication of any errors
-If i stay on the "System Information" screen or any other screen, the OctoScreen does not crash
May 31 00:36:26 octopi systemd[1]: octoscreen.service: Watchdog timeout (limit 20s)!
May 31 00:36:26 octopi systemd[1]: octoscreen.service: Killing process 4119 (xinit) with signal SIGABRT.
May 31 00:36:26 octopi systemd[1]: octoscreen.service: Killing process 4120 (Xorg) with signal SIGABRT.
May 31 00:36:26 octopi xinit[4119]: (EE)
May 31 00:36:26 octopi xinit[4119]: (EE) Backtrace:
May 31 00:36:26 octopi xinit[4119]: (EE) Received signal 6 sent by process 1, uid 0
May 31 00:36:26 octopi xinit[4119]: Fatal server error:
May 31 00:36:26 octopi xinit[4119]: (EE) Caught signal 6 (Aborted). Server aborting
May 31 00:36:26 octopi xinit[4119]: Please consult the The X.Org Foundation support
May 31 00:36:26 octopi xinit[4119]: #011 at http://wiki.x.org
May 31 00:36:26 octopi xinit[4119]:  for help.
May 31 00:36:26 octopi xinit[4119]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
May 31 00:36:26 octopi xinit[4119]: (II) AIGLX: Suspending AIGLX clients for VT switch
May 31 00:36:26 octopi systemd[1]: octoscreen.service: Killing process 4150 (OctoScreen) with signal SIGABRT.
May 31 00:36:26 octopi systemd[1]: octoscreen.service: Main process exited, code=killed, status=6/ABRT
May 31 00:36:26 octopi xinit[4119]: SIGABRT: abort(EE) Server terminated with error (1). Closing log file.
May 31 00:36:26 octopi systemd[1]: octoscreen.service: Failed with result 'watchdog'.
May 31 00:36:26 octopi systemd[1]: octoscreen.service: Service RestartSec=100ms expired, scheduling restart.
May 31 00:36:26 octopi systemd[1]: octoscreen.service: Scheduled restart job, restart counter is at 99.
May 31 00:36:26 octopi systemd[1]: Stopped OctoScreen.
May 31 00:36:26 octopi systemd[1]: Starting OctoScreen...
May 31 00:36:27 octopi xinit[4775]: X.Org X Server 1.20.4
May 31 00:36:27 octopi xinit[4775]: X Protocol Version 11, Revision 0
May 31 00:36:27 octopi xinit[4775]: Build Operating System: Linux 5.4.0-54-generic armv8l Raspbian
May 31 00:36:27 octopi xinit[4775]: Current Operating System: Linux octopi 5.4.79-v7l+ #1373 SMP Mon Nov 23 13:27:40 GMT 2020 armv7l
May 31 00:36:27 octopi xinit[4775]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:89:10:24 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=bd8064d1-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait spidev.bufsiz=32768
Greetings and I hope you are all well.
Exactly the same thing happens to me as AndyDiags, the difference I have:
Raspberry Pi 4 B 4 Gigas
Ender 3 V2
OctoPrint v1.6.1
OctoScreen 2.7.3
OctoScreen Plugin "Not Installing"
7 "inch HDMI LCD Touch screen.
