I have two printers, a Wanhao i3 which has manual fan speed control overriding gcode to some degree via the control knob. I also have a Creality CR10s Pro v2 which lacks anything beyond fan on/off control.
Octoprint used to have a plug in that sent fan speed via a slider and on/off to the printer, no feedback obviously but it worked really well once understood, a bit like there is no feedback for FlowRate and FeedRate.
Is anything like this available now? it is sorely missed .
I'm not that experienced, ... Edit, found .octoprint it and added to bottom of the config.yaml file
EDIT: I tried entering the script at the end, the server would not start, so I guess I'm doing something wrong!? Where do I put the script, does it matter?
I am aware of the part cooling fan speed control on the Wanhao i3 box in hardware/firmware but not for the Creality CR10S Pro V2, it seems to just have on/off via the touch screen.
