ive checked everything does someone know what i need to do? i got everything right the wifi the country everything but still no succes.
You may connect a HDMI TV/monitor to the Pi.
At the end of the login sequence you should see if the Pi has connected to the WiFi and on what IP address.
and if not connected whats then the problem?
Where did you get raspberry pi imager 1.9.0? The latest is 1.8.5, I just went to the rasperry pi downloads site to verify.
https://www.raspberrypi.com/software/
I had the same question but I answered it myself:
i tried it on another computer and network and it worked fine, could it be because i am an older computer or that my network here is just so bad?
i just checked the image it also says 1.8.5 but when i launch via programs it just lanches v1.9.0
update.
i got it working i was running the wrong packet and my network provider blocked the raspberry pi from the network so i got it running now.
Thanks for all the help guys i understand a lot more now.
