Is there a Plugin for Octoprint that displays a G Code viewer that shows X & Y scales in mm on the display?
I'm not sure I understand the question. The only relevant plugin that might do this would be Pretty GCode since it's the only one that actually recreates the viewer. All other plugins related to gcode viewer are the cancel object and exclude region plugins, which are for picking objects on the viewer.
Thank you for your reply.
I was referring to the grid that is displayed in the GCode Viewer. It would be useful if that grid had rulers on the X & Y axes showing the sizes in mm.
