Hi, I have no programming experience so forgive me for that😊 I am also a quadriplegic and struggle to type so forgive my sentence structure.
My suggestion for an octoprint plugin is one that runs a bed levelling process at the start of every print and if the bed variance is greater than a predetermined amount It pauses the print.
This requires obviously aN auto bed levelling setup.
This seems seems like something that should be easy to do?
and to make sure you don’t start a print where the bed level is off for some reason. For exampleGetting a piece of plastic under the flexible build plate, or somebody’s bashed the printer, or maybe printing out at a new temperature which significantly affects the build plate levelLing.
I have a prusa mk3 Which I know has a built-in compensation for unlevel bed but it doesn’t cope with these situations in my experience. I got someone to add the Nylok bed levelling upgrade to get the variance low.
So To reiterate:
Run a bed level
Calculate the variance
Compare variance to preset allowance
If within limits continue print
If outside limits Pause print and send message
What do you think?
Andy
