I've been working on a plugin to add an API end point to automatically load the next file in the current folder. My use case is that I have an IoT button that I currently have setup that calls the API end point to start printing (so if I have a file currently loaded I can re-print it) and I'd like to add a new end point to move on to the next file (for this particular definition of next) when I double press or hold down the IoT button.
I currently have it working, but this is my first python project and first Octoprint Plugin so I'm just curious if there are better ways to go about what I'm doing.
Thank you for any advice/critiques!
# -*- coding: utf-8 -*-
from __future__ import absolute_import, unicode_literals
import octoprint.plugin
import flask
import os
class LoadNextFilePlugin(octoprint.plugin.SimpleApiPlugin):
def on_api_get(self, request):
if self._printer.is_closed_or_error():
return flask.jsonify(printer="is_closed_or_error")
jobData = self._printer.get_current_job()
if jobData["file"]["path"] != None:
# we have a job - save some information about the current file
origin = jobData["file"]["origin"]
isSD = origin != "local"
currentPath = jobData["file"]["path"]
currentName = jobData["file"]["name"]
currentDisplayName = jobData["file"]["display"]
currentFolder = os.path.dirname(jobData["file"]["path"])
# get all the files and folders in the current folder
folderFilesAndFolders = self._file_manager.list_files(path=currentFolder, recursive=False)[origin]
# filter the list to have just the files - can't use filter on list_files because it seems to always include folders
folderFiles = {}
for key, node in folderFilesAndFolders.items():
if node["type"] != "folder":
folderFiles[key] = node
# sort the files in the desired manner
sortedFiles = sorted(folderFiles.keys())
# figure out the index of the next file (looping)
currentIndexIntoSorted = sortedFiles.index(currentName)
nextIndex = currentIndexIntoSorted + 1
if nextIndex == len(sortedFiles):
nextIndex = 0
# store the info for the next file
nextFileInfo = folderFiles[sortedFiles[nextIndex]]
nextASCIIName = nextFileInfo["name"]
nextPath = nextFileInfo["path"]
# select the file
self._printer.select_file(nextPath, isSD)
# update the printer display to let us know it worked
self._printer.commands("M117 Loaded {0}".format(nextASCIIName))
responseData = { "old": currentName, "new": nextASCIIName }
return flask.jsonify(responseData)
else:
self._printer.commands("M117 No File Loaded")
return flask.jsonify(noFileCurrentlyLoaded="true")
__plugin_name__ = "LoadNextFile"
__plugin_version__ = "0.1.0"
__plugin_description__ = "Adds an API endpoint to load the next file in the current folder alphabetically"
__plugin_pythoncompat__ = ">=2.7,<4"
__plugin_implementation__ = LoadNextFilePlugin()
