Problem: some two wire part cooling fans require a spin up to 100% before they can effectively spin down to a lower percentage. This fellow calls it 'blipping'
From Reddit : "(...) In addition to "the fan is usually off for the first layers" that others have posted, these fans tend to not spin at lower percentages (30 and less) unless your slicer supports "blipping" the fan to full power when it starts. This gets the fan started by going full power, then dropping to your set percentage." -- xXsaberstrikeXx
Ideally this should be an option in the slicer software, but so far, I've seen nothing in Cura/Prusa so I was wondering if some clever individual would write a plugin that can intercept M106 gcodes and 'blip' the fan to full speed (momentarily) where appropriate. example: if M106 S80 found in gcode then M106 S255 sent immediately before hand. I imagine the value of 'S' would be user configured in the plugin because different fans may require it -- my fan can start spinning at values over 100 so the plugin would not need to blip the fan.
well, none of the Creality Ender models have PWM hotend/part fans... and i'm looking very closely at other manufacturers. In the mean time, it seems to be quite an undertaking to post process a gcode file on octoprint... but it's nice to know that if I had a new controller board and new PWM fans marlin 'seems' compatible.
Where have you found this? My Ender 5 Pro seems to have a PWM part fan and runs just fine. Can't see anything in the Marlin config that suggests it is not using PWM, and the speed varies just fine. How else do they vary the speed in this case?
I haven't tested this but it should get you close in case you would like to write a plugin instead of playing with the firmware.
# coding=utf-8
import octoprint.plugin
import re
class FanBlip(octoprint.plugin.OctoPrintPlugin):
def rewrite_m106(self, comm_instance, phase, cmd, cmd_type, gcode, *args, **kwargs):
if gcode and gcode == "M106":
CmdDict = dict ((x,float(y)) for d,x,y in (re.split('([A-Z])', i) for i in cmd.upper().split()))
if "S" in CmdDict:
s = int(CmdDict["S"])
if s < 100:
cmd = [("M106 S255"), #Full Speed
("G4 S1"), # Wait a second
("M106 S" + str(s))] #Back to the set value
self._logger.info("Bliping the fan")
return cmd
else:
return None
__plugin_name__ = "FanBlip"
__plugin_pythoncompat__ = ">=2.7,<4"
def __plugin_load__():
global __plugin_implementation__
__plugin_implementation__ = FanBlip()
global __plugin_hooks__
__plugin_hooks__ = {
"octoprint.comm.protocol.gcode.queuing": __plugin_implementation__.rewrite_m106
put it in a file called fanblip.py and place it in your OP plugin folder.
