Plugins That Put Camera in Sidebar
I've been using Sidebar Webcam for a long time without issue, but since switching to the new camera stack when I rotate the camera 90degree's in Sidebar Webcam (rotation I set in Classic Webcam doesn't carry though) the image goes smaller.
I used to run 1024x768 (set by raspi in octopi.txt) and plugin worked fine, but since this issue have been trying different aspect ratios and resolutions but no joy (its set as 768x768 in the screenshots).
Anyone know of any other plugins that do the same job that may not have an issue or how to resolve this?
I can't help you with this plugin, but maybe a different plugin with similar or the same features works better for you
+1 for UI Customizer. It has a built-in webcam widget that you can move around in the sidebars, plus a whole lot more.
thanks for this - infact it replaces many plugins I had loaded to do the same jobs
it definitely does replace a whole bunch of mine.
I was using Tab Order, Sidebar Webcam, Dashboard but most of all Themify for Discoranged,
Yeah Tab Order is mine, and I actually contributed the discoranged theme to UI Customizer because I too contributed/used it with Themify previously.
