FYI, I just added some code to Octolapse that will re-add the default confirm buttons to PNotify if they are missing. If your plugin removes the default buttons via the following javascript:
PNotify.prototype.options.confirm.buttons = [];
your plugin will be semi-broken (or at least it will look ugly) by Octolapse. I did this because there are many plugins (most are now patched) that remove all of these buttons, and having an OK and CANCEL button is kind of important for a confirmation dialog
If you need to remove PNotify confirm buttons, use something like the following instead:
new PNotify({
title: "My confirm message",
text: "Some text here",
type: "error",
confirm: {
confirm: true,
buttons: [
text: "No thank you!",
click: function(notice) {
my_function();
notice.remove();
text: "Close", // This is the text of the button we want to remove
addClass: "remove_button" // Add a class to the button so you can find it later
before_open: function(notice) {
// Remove the button we don't want
notice.get().find(".remove_button").remove();
Thanks!
