Hello everyone,
I'm trying to install the Polar Cloud plugin that was mentioned on a recent blog of Gina's. It is failing for me
Any assistance would be greatly appreciated. In the log it mentions having an older version of pip, so I tried upgrading that and that failed too.... btw, I just tried installing the plugin using OctoPrint's plugin manager. Here is my setup information below, then the log error.
OctoPrint Version 1.3.9
OctoPi Version 0.13.0
RPi 2b
pip 9.0.1 from /home/pi/oprint/local/lib/python2.7/site-packages (python 2.7)
Linux version 4.9.35-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 SMP Fri Jun 30 14:47:43 BST 2017
Prusa i3 MK2 - firmware 3.1.0 - 11/12/2017
octoprint.log
2018-09-22 17:18:46,821 - octoprint.plugin.core - INFO - Initialized 23 plugin implementation(s)
2018-09-22 17:18:46,856 - octoprint.plugin.core - INFO - 23 plugin(s) registered with the system:
| Automatic Shutdown (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_automaticshutdown
| Bed Visualizer (0.1.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
| DisplayProgress (0.1.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_displayprogress
| Email Notifier (0.1.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_emailnotifier
| FileManager (0.1.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filemanager
| Fullscreen Plugin (0.0.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fullscreen
| Octolapse (v0.3.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| OctoPi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/octopi_support
| Octoslack (1.5.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_Octoslack
| Print History Plugin (1.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_printhistory
| Printer Stats (1.0.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_stats
| Shutdown Printer (0.0.8) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_shutdownprinter
| TP-Link Smartplug (0.9.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_tplinksmartplug
2018-09-22 17:18:46,881 - octoprint.environment - INFO - Detected environment is Python 2.7.9 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 900.0
| ram: 901689344
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: 2B
| revision: a01041
| version: 0.13.0
| python:
| pip: 9.0.1
| version: 2.7.9
| virtualenv: /home/pi/oprint
2018-09-22 17:18:46,904 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2018-09-22 17:18:46,944 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2018-09-22 17:18:46,964 - octoprint.plugins.octolapse - INFO - Octolapse is loading assets.
2018-09-22 17:18:47,335 - octoprint.server - INFO - Shutting down intermediary server...
2018-09-22 17:18:47,794 - octoprint.server - INFO - Intermediary server shut down
2018-09-22 17:18:47,799 - octoprint.events - INFO - Processing startup event, this is our first event
2018-09-22 17:18:47,821 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2018-09-22 17:18:47,837 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-09-22 17:18:47,921 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-09-22 17:18:49,177 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-09-22 17:18:49,264 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-09-22 17:18:49,268 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2018-09-22 17:18:49,311 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-09-22 17:18:49,390 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _http._tcp
2018-09-22 17:18:49,446 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _octoprint._tcp
2018-09-22 17:18:49,490 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2018-09-22 17:18:49,582 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2018-09-22 17:18:49,625 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrint-BedLevelVisualizer loaded!
2018-09-22 17:18:49,628 - octoprint.plugins.octolapse - INFO - Loading existing settings file from: /home/pi/.octoprint/data/octolapse/settings.json.
2018-09-22 17:18:50,324 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-09-22 17:18:50,590 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-09-22 17:18:50,719 - octoprint.plugins.stats - INFO - Printer Stats
2018-09-22 17:18:50,839 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-09-22 17:18:51,085 - octoprint.plugins.tplinksmartplug - INFO - TPLinkSmartplug loaded!
2018-09-22 17:18:51,218 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'https ://192.168.254.29/'}
2018-09-22 17:18:51,301 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-09-22 17:18:52,039 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2018-09-22 17:18:52,056 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-09-22 17:18:52,126 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin V1.0.2; Sprinter/grbl mashup for gen6"
2018-09-22 17:18:52,853 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.254.12
2018-09-22 17:18:55,666 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2018-09-22 17:19:05,339 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2018-09-22 17:19:05,340 - octoprint.util.pip - INFO - ==> pip ok -> yes
2018-09-22 17:19:06,443 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2018-09-22 17:19:23,272 - octoprint.server.preemptive_cache - INFO - ... done in 32.05s
2018-09-22 17:19:23,273 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.254.29/'}
2018-09-22 17:19:35,620 - octoprint.server.preemptive_cache - INFO - ... done in 12.35s
2018-09-22 17:19:35,622 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'https ://octopi.local/'}
2018-09-22 17:19:47,772 - octoprint.server.preemptive_cache - INFO - ... done in 12.15s
2018-09-22 17:20:00,098 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.254.12
2018-09-22 17:20:01,158 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.254.12
2018-09-22 17:20:19,254 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2018-09-22 17:20:44,176 - octoprint.plugins.pluginmanager - INFO - Installing plugin from https ://github.com/markwal/OctoPrint-PolarCloud/archive/master.zip
2018-09-22 17:21:33,095 - octoprint.plugins.pluginmanager - ERROR - Installing the plugin from https ://github.com/markwal/OctoPrint-PolarCloud/archive/master.zip failed, could not parse output from pip. See plugin_pluginmanager_console.log for generated output
2018-09-22 17:33:35,286 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-09-22 17:39:25,338 - octoprint.plugins.pluginmanager - INFO - Installing plugin from https ://github.com/markwal/OctoPrint-PolarCloud/archive/master.zip
2018-09-22 17:40:09,219 - octoprint.plugins.pluginmanager - ERROR - Installing the plugin from https ://github.com/markwal/OctoPrint-PolarCloud/archive/master.zip failed, could not parse output from pip. See plugin_pluginmanager_console.log for generated output
2018-09-22 17:48:35,287 - octoprint.server.heartbeat - INFO - Server heartbeat <3
