Print Job History - set/change default camera for snapshot?
Hi there.
I just started using the plugin and its pretty cool but the camera it uses to take the snapshot at the end is not the one I want.
I looked at the settings, and unless I completely missed it, I can't find a way to tell it what camera I want it to use.
Is there anyway to do this, even if it is via a text editor via SSH is fine.
Thanks!
j
Which camera have you set up in the 'Webcam & Timelapse' settings of OctoPrint? If there is nowhere to configure it in the plugin, I would suggest it uses the one configured there. You can only configure one so that is the one it will use.
