Is there any way from The Octoprint terminal or plug-in to show info on your printers motherboard? I have an ender 3v2 and cannot recall which version of the motherboard i have and hoping to be able to pull that without flipping it over and taking the cover off if possible. Not the end of the world if I have to but thought if it's possible through terminal, awesome!
Not likely possible - the most information you get out of the printer is by sending the M115 command, which OctoPrint does when it connects. I don't think there's anything that will give you the board revision.
I figured it was a long shot. Ultimately I'm just trying to find what I have so I can figure out what firmware I need to switch to so I can use the autobrim plugin
