JL-EU
1
Tried to install the Printer Statistics plugin on OctoPrint via the plugin manager but it hangs during the installation process, see screenshot.
I am running Version 1.6.1 of OctoPrint in a Docker container on a Raspberrypi3 A+.
Installed ''apt install libatlas-base-dev'' in the container as advised on: GitHub - AlexVerrico/octoprint-stats: Stats for your octoprint instance. Mirrored from https://github.com/amsbr/OctoPrint-Stats originally but it didn't help.
Any advice is welcome. Thanks.
JL-EU
2
Tried manual install, but same result the installation process stops:
Do you have any news about the problem?
I have the same issue.
Octoprint 1.7.0 running in docker on a RaspberryPi 3 (raspbian buster, 5.10.63-v7+)
root@9bdecf5f37ca:/octoprint# pip install "https://github.com/AlexVerrico/octoprint-stats/archive/master.zip"
Collecting https://github.com/AlexVerrico/octoprint-stats/archive/master.zip
Using cached https://github.com/AlexVerrico/octoprint-stats/archive/master.zip
Preparing metadata (setup.py) ... done
Requirement already satisfied: OctoPrint in ./plugins/lib/python3.8/site-packages (from OctoPrint-Stats==3.1.2) (1.7.0)
Collecting tinydb
Using cached tinydb-4.5.2-py3-none-any.whl (23 kB)
Collecting pandas
Using cached pandas-1.3.3.tar.gz (4.7 MB)
Installing build dependencies ... done
Getting requirements to build wheel ... -
After some time the raspberry pi hangs up and does not respond until power-cycle.
