Thank you very much for your answer.
My Octoprint version is 1.3.11 (OctoPi 0.16.0)
Here is the listing of what is displayed during the plugin update procedure:
Mise ร jour de Printer Stats vers la version 2.0.0
/home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/amsbr/OctoPrint-Stats/archive/2.0.0.zip --no-cache-dir
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting https://github.com/amsbr/OctoPrint-Stats/archive/2.0.0.zip
Downloading https://github.com/amsbr/OctoPrint-Stats/archive/2.0.0.zip
Requirement already satisfied: OctoPrint in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint-Stats==2.0.0) (1.3.11)
Collecting tinydb (from OctoPrint-Stats==2.0.0)
Downloading https://files.pythonhosted.org/packages/d7/f9/0e871cbf0da678cf1780609dc6aef26a5ed544c86733fc1ceaf134fce52c/tinydb-3.13.0-py2.py3-none-any.whl
Collecting pandas (from OctoPrint-Stats==2.0.0)
Downloading https://files.pythonhosted.org/packages/b2/4c/b6f966ac91c5670ba4ef0b0b5613b5379e3c7abdfad4e7b89a87d73bae13/pandas-0.24.2.tar.gz (11.8MB)
Complete output from command python setup.py egg_info:
File "", line 1, in
File "/tmp/pip-install-Hl2Bcm/pandas/setup.py", line 746, in
**setuptools_kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/init.py", line 144, in setup
_install_setup_requires(attrs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/init.py", line 139, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 724, in fetch_build_eggs
replace_conflicting=True,
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/init.py", line 846, in resolve
dist = best[req.key] = env.best_match(req, ws, installer)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/init.py", line 1118, in best_match
return self.obtain(req, installer)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/init.py", line 1130, in obtain
return installer(requirement)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 791, in fetch_build_egg
return cmd.easy_install(req)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 679, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 705, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 890, in install_eggs
return self.build_and_install(setup_script, setup_base)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 1158, in build_and_install
self.run_setup(setup_script, setup_base, args)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 1144, in run_setup
run_setup(setup_script, args)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 253, in run_setup
raise
File "/usr/lib/python2.7/contextlib.py", line 35, in exit
self.gen.throw(type, value, traceback)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 195, in setup_context
yield
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 166, in save_modules
saved_exc.resume()
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 141, in resume
six.reraise(type, exc, self._tb)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 154, in save_modules
yield saved
yield
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 250, in run_setup
_execfile(setup_script, ns)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 45, in _execfile
exec(code, globals, locals)
File "/tmp/easy_install-iLc5Hl/numpy-1.17.2/setup.py", line 31, in
RuntimeError: Python version >= 3.5 required.
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-Hl2Bcm/pandas/
The update did not finish successfully. Please consult octoprint.log and plugin_softwareupdate_console.log for details.
