Hi all,
already postet on Ollis Git as an issue other ones have the same problem.
Mad a complete new copy with 0.18 as a base,
after uploading the backup from teh 0.17 installation the PrintJobhistory is installed but not there.
Found portions in the config.yaml and the plugin itself in oprint pyton section
but it is not installed in the Pluginmanger!
No what I do it every time says it is succefully installed but not in Pluginmanager!
This is the log during installation may be somebody can find out why it is not working:
Installiere Plugin "PrintJobHistory" von https://github.com/OllisGit/OctoPrint-PrintJobHistory/releases/latest/download/master.zip...
/home/pi/oprint/bin/python3 -m pip --disable-pip-version-check install file:///tmp/tmpjc_xi11s/master.zip --no-cache-dir
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Processing /tmp/tmpjc_xi11s/master.zip
Requirement already satisfied: OctoPrint in /home/pi/oprint/lib/python3.7/site-packages (from Print-Job-History==1.11.0.dev0) (1.5.3)
Requirement already satisfied: pillow>=6.2.0<7.0.0 in /home/pi/oprint/lib/python3.7/site-packages (from Print-Job-History==1.11.0.dev0) (8.2.0)
Requirement already satisfied: peewee in /home/pi/oprint/lib/python3.7/site-packages (from Print-Job-History==1.11.0.dev0) (3.14.4)
Requirement already satisfied: netifaces<1,>=0.10.9 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.10.9)
Requirement already satisfied: wrapt<2,>=1.12.1 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (1.12.1)
Requirement already satisfied: future<1,>=0.18.2 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.18.2)
Requirement already satisfied: pylru<2,>=1.2 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (1.2.0)
Requirement already satisfied: Flask-Login<0.6,>=0.5 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.5.0)
Requirement already satisfied: watchdog==0.10.4 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.10.4)
Requirement already satisfied: frozendict<2,>=1.2 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (1.2)
Requirement already satisfied: unidecode<0.05,>=0.04.14 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.4.21)
Requirement already satisfied: flask<2,>=1.1.2 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (1.1.2)
Requirement already satisfied: cachelib<1,>=0.1 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.1.1)
Requirement already satisfied: filetype<2,>=1.0.7 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (1.0.7)
Requirement already satisfied: zeroconf<0.25,>=0.24 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.24.5)
Requirement already satisfied: markdown<3.2,>=3.1 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (3.1.1)
Requirement already satisfied: Jinja2<3,>=2.11.2 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (2.11.2)
Requirement already satisfied: semantic-version<3,>=2.8.5 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (2.8.5)
Requirement already satisfied: Click<8,>=7.1.2 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (7.1.2)
Requirement already satisfied: emoji<1,>=0.5.4 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.6.0)
Requirement already satisfied: OctoPrint-FileCheck>=2020.08.07 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (2021.2.23)
Requirement already satisfied: sarge==0.1.5post0 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.1.5.post0)
Requirement already satisfied: feedparser<7,>=6.0.2 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (6.0.2)
Requirement already satisfied: websocket-client<1,>=0.57 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.57.0)
Requirement already satisfied: pyserial<4,>=3.4 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (3.5)
Requirement already satisfied: markupsafe<2.0,>=1.1 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (1.1.1)
Requirement already satisfied: requests<3,>=2.23.0 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (2.25.1)
Requirement already satisfied: tornado==5.1.1 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (5.1.1)
Requirement already satisfied: blinker<2,>=1.4 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (1.4)
Requirement already satisfied: regex!=2018.11.6 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (2020.11.13)
Requirement already satisfied: netaddr<1,>=0.7.19 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.8.0)
Requirement already satisfied: itsdangerous<2,>=1.1.0 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (1.1.0)
Requirement already satisfied: Flask-Assets<3,>=2.0 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (2.0)
Requirement already satisfied: Flask-Babel<2,>=1.0 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (1.0.0)
Requirement already satisfied: PyYAML<6,>=5.3.1 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (5.3.1)
Requirement already satisfied: werkzeug<2,>=1.0.1 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (1.0.1)
Requirement already satisfied: rsa==4.0 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (4.0)
Requirement already satisfied: sentry-sdk<1,>=0.15.1 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (0.19.5)
Requirement already satisfied: psutil<6,>=5.7 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (5.8.0)
Requirement already satisfied: pkginfo<2,>=1.5.0.1 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (1.6.1)
Requirement already satisfied: OctoPrint-FirmwareCheck>=2020.09.23 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->Print-Job-History==1.11.0.dev0) (2021.2.4)
Requirement already satisfied: pyasn1>=0.1.3 in /home/pi/oprint/lib/python3.7/site-packages (from rsa==4.0->OctoPrint->Print-Job-History==1.11.0.dev0) (0.4.8)
Requirement already satisfied: pathtools>=0.1.1 in /home/pi/oprint/lib/python3.7/site-packages (from watchdog==0.10.4->OctoPrint->Print-Job-History==1.11.0.dev0) (0.1.2)
Requirement already satisfied: sgmllib3k in /home/pi/oprint/lib/python3.7/site-packages (from feedparser<7,>=6.0.2->OctoPrint->Print-Job-History==1.11.0.dev0) (1.0.0)
Requirement already satisfied: webassets>=2.0 in /home/pi/oprint/lib/python3.7/site-packages (from Flask-Assets<3,>=2.0->OctoPrint->Print-Job-History==1.11.0.dev0) (2.0)
Requirement already satisfied: Babel>=2.3 in /home/pi/oprint/lib/python3.7/site-packages (from Flask-Babel<2,>=1.0->OctoPrint->Print-Job-History==1.11.0.dev0) (2.9.0)
Requirement already satisfied: pytz in /home/pi/oprint/lib/python3.7/site-packages (from Flask-Babel<2,>=1.0->OctoPrint->Print-Job-History==1.11.0.dev0) (2020.5)
Requirement already satisfied: setuptools>=36 in /home/pi/oprint/lib/python3.7/site-packages (from markdown<3.2,>=3.1->OctoPrint->Print-Job-History==1.11.0.dev0) (51.1.2)
Requirement already satisfied: idna<3,>=2.5 in /home/pi/oprint/lib/python3.7/site-packages (from requests<3,>=2.23.0->OctoPrint->Print-Job-History==1.11.0.dev0) (2.10)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /home/pi/oprint/lib/python3.7/site-packages (from requests<3,>=2.23.0->OctoPrint->Print-Job-History==1.11.0.dev0) (1.26.2)
Requirement already satisfied: chardet<5,>=3.0.2 in /home/pi/oprint/lib/python3.7/site-packages (from requests<3,>=2.23.0->OctoPrint->Print-Job-History==1.11.0.dev0) (4.0.0)
Requirement already satisfied: certifi>=2017.4.17 in /home/pi/oprint/lib/python3.7/site-packages (from requests<3,>=2.23.0->OctoPrint->Print-Job-History==1.11.0.dev0) (2020.12.5)
Requirement already satisfied: six in /home/pi/oprint/lib/python3.7/site-packages (from websocket-client<1,>=0.57->OctoPrint->Print-Job-History==1.11.0.dev0) (1.15.0)
Requirement already satisfied: ifaddr in /home/pi/oprint/lib/python3.7/site-packages (from zeroconf<0.25,>=0.24->OctoPrint->Print-Job-History==1.11.0.dev0) (0.1.7)
Building wheels for collected packages: Print-Job-History
Building wheel for Print-Job-History (setup.py): started
Building wheel for Print-Job-History (setup.py): finished with status 'done'
Created wheel for Print-Job-History: filename=Print_Job_History-1.11.0.dev0-py3-none-any.whl size=274190 sha256=9affd5974b1672586cb8a67431d77e071fdd5019b19b91893b70824f2ee8da2c
Stored in directory: /tmp/pip-ephem-wheel-cache-kdvzm91k/wheels/c0/45/f2/fa19f2ea8bb7bbcd5a589d41bd6c9a42bd9eff6a0ce82631c5
Successfully built Print-Job-History
Installing collected packages: Print-Job-History
Attempting uninstall: Print-Job-History
Found existing installation: Print-Job-History 1.11.0.dev0
Uninstalling Print-Job-History-1.11.0.dev0:
Successfully uninstalled Print-Job-History-1.11.0.dev0
Successfully installed Print-Job-History-1.11.0.dev0
Fertig!
