Hello,
I've tried to use the JavaScript Client Library to connect to push updates, but I can't seem to initialize the SockJS Object.
Here's the error message:
Uncaught TypeError: SockJS is not a constructor
at OctoPrintSocketClient.connect (http://127.0.0.1:5000/static/webassets/packed_client.js:488:23)
my relevant code:
<script src="./node_modules/jquery/dist/jquery.min.js"></script>
<script src="http://127.0.0.1:5000/static/js/lib/lodash.min.js"></script>
<script src="http://127.0.0.1:5000/static/webassets/packed_client.js"></script>
OctoPrint.options.baseurl = "http://127.0.0.1:5000/"
OctoPrint.options.apikey = "11D742B6682D46709154B045CC222B0D";
OctoPrint.files.list()
.done(function (response)
console.log(response)
// do something with the response
OctoPrint.socket.connect()
The file list works without problem.
Tried to use reconnect instead of connect, but same issue.
Does someone know what could be my error?
Used OctoPrint Version: 1.3.10.post5+g8ce2290d
