Hello
I have a problem with this project
I have everything built but I came across a problem with the octoprint plugin. As if the python wasn't compatible.
Here is the plugin code:
Can anyone please help me with this?
Thank you ![]()
Martin
Hello
Thank you ![]()
Martin
The file linked is not an actual OctoPrint plugin it is just a script that can be run from the command line, so 'installing it' in the plugin manager is not the intended way of it working.
