I have a smart plug set up as my switching device by configuring the address to the switch's local ipaddress however when I use the toggle in octoprint it doesn't seem to work at all. The plug remains on.
I am wondering if this is caused by there being two "plugs" on that ip address (the smart plug has two plugs and I am not sure if there is a way to tell it which plug to select. The plug is a TP25
My goal is to have the psu off until a print is started at which point it would turn on automatically and then back off when the print finishes. However even getting the toggle to work would be a start.
edit: I should add that I would have no problem with it controlling both plugs and the other would likely be a lamp to allow lighting for my camera if that were the case.
octoprint-systeminfo-20240126195631.zip (681.5 KB)
