I'm trying to modify the GPIO Control plugin to be able to work on an Orange Pi. I changed the plugin_requires variable in setup.py to OrangePi.GPIO and changed the corresponding import command in __init__.py.
But when I run python3 setup.py develop it exits with this error:
~/devel/OctoPrint-GpioControl$ python3 setup.py develop
Found packages: {'octoprint_gpiocontrol'}
running develop
running egg_info
writing OctoPrint_GpioControl.egg-info/PKG-INFO
writing dependency_links to OctoPrint_GpioControl.egg-info/dependency_links.txt
writing entry points to OctoPrint_GpioControl.egg-info/entry_points.txt
writing requirements to OctoPrint_GpioControl.egg-info/requires.txt
writing top-level names to OctoPrint_GpioControl.egg-info/top_level.txt
reading manifest file 'OctoPrint_GpioControl.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*' under directory 'octoprint_gpiocontrol/translations'
writing manifest file 'OctoPrint_GpioControl.egg-info/SOURCES.txt'
running build_ext
Creating /home/pi/oprint/lib/python3.9/site-packages/OctoPrint-GpioControl.egg-link (link to .)
OctoPrint-GpioControl 1.0.8 is already the active version in easy-install.pth
Installed /home/pi/devel/OctoPrint-GpioControl
Processing dependencies for OctoPrint-GpioControl==1.0.8
Searching for OrangePi.GPIO
Reading https://pypi.org/simple/OrangePi.GPIO/
Downloading https://files.pythonhosted.org/packages/04/b1/c9589b308e2ee52e6f6710b7f0dc1fc07061b70ebd2fe28ec2308b556138/OrangePi.GPIO-0.6.3.tar.gz#sha256=89cfaf1114ea926c2a8e9b822511709bedab780310a927ce6ee5140d2dbecf51
Best match: OrangePi.GPIO 0.6.3
Processing OrangePi.GPIO-0.6.3.tar.gz
Writing /tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/setup.cfg
Running OrangePi.GPIO-0.6.3/setup.py -q bdist_egg --dist-dir /tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/egg-dist-tmp-dioixcx4
source/c_gpio.c: In function ‘readl’:
source/c_gpio.c:39:63: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 4 has type ‘volatile uint32_t *’ {aka ‘volatile unsigned int *’} [-Wformat=]
39 | printf("mmap_base = 0x%x\t mmap_seek = 0x%x\t gpio_map = 0x%x\t total = 0x%x\n",mmap_base,mmap_seek,gpio_map,(gpio_map + mmap_seek));
| unsigned int volatile uint32_t * {aka volatile unsigned int *}
| %ls
source/c_gpio.c:39:78: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 5 has type ‘volatile uint32_t *’ {aka ‘volatile unsigned int *’} [-Wformat=]
39 | se = 0x%x\t mmap_seek = 0x%x\t gpio_map = 0x%x\t total = 0x%x\n",mmap_base,mmap_seek,gpio_map,(gpio_map + mmap_seek));
| %ls
source/c_gpio.c: In function ‘setup’:
source/c_gpio.c:64:6: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
64 | if ((uint32_t)gpio_mem % PAGE_SIZE)
source/c_gpio.c:65:28: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
65 | gpio_mem += PAGE_SIZE - ((uint32_t)gpio_mem % PAGE_SIZE);
source/c_gpio.c:70:25: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 2 has type ‘uint8_t *’ {aka ‘unsigned char *’} [-Wformat=]
70 | printf("gpio_mem = 0x%x\t gpio_map = 0x%x\n",gpio_mem,gpio_map);
| unsigned int uint8_t * {aka unsigned char *}
| %hhn
source/c_gpio.c:70:43: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 3 has type ‘volatile uint32_t *’ {aka ‘volatile unsigned int *’} [-Wformat=]
| %ls
source/c_gpio.c:72:6: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
72 | if ((uint32_t)gpio_map < 0)
source/event_gpio.c: In function ‘event_cleanup’:
source/event_gpio.c:444:15: warning: comparison of integer expressions of different signedness: ‘unsigned int’ and ‘int’ [-Wsign-compare]
444 | if ((gpio == -666) || (gpio_list->gpio == gpio))
source/py_gpio.c: In function ‘py_gpio_function_string’:
source/py_gpio.c:354:7: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
354 | str = FUNCTIONS[fn];
source/py_gpio.c: In function ‘PyInit_GPIO’:
source/py_gpio.c:730:3: warning: ‘PyEval_ThreadsInitialized’ is deprecated [-Wdeprecated-declarations]
730 | if (!PyEval_ThreadsInitialized())
In file included from /usr/include/python3.9/Python.h:145,
from source/py_gpio.c:23:
/usr/include/python3.9/ceval.h:129:36: note: declared here
129 | Py_DEPRECATED(3.9) PyAPI_FUNC(int) PyEval_ThreadsInitialized(void);
source/py_gpio.c:731:5: warning: ‘PyEval_InitThreads’ is deprecated [-Wdeprecated-declarations]
731 | PyEval_InitThreads();
/usr/include/python3.9/ceval.h:130:37: note: declared here
130 | Py_DEPRECATED(3.9) PyAPI_FUNC(void) PyEval_InitThreads(void);
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: multiple definition of `gpio_mode'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: multiple definition of `pin_to_gpio'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: multiple definition of `setup_error'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: multiple definition of `module_setup'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: multiple definition of `gpio_direction'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: multiple definition of `board_type'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:29: multiple definition of `FUNCTIONS'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:29: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:27: multiple definition of `pin_to_gpio_prime'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:27: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:26: multiple definition of `pin_to_gpio_pc2'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:26: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:25: multiple definition of `pin_to_gpio_pc'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:25: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:24: multiple definition of `pin_to_gpio_zero2'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:24: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/common.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:23: multiple definition of `pin_to_gpio_zero'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:23: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: multiple definition of `module_setup'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: multiple definition of `setup_error'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: multiple definition of `gpio_direction'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: multiple definition of `pin_to_gpio'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: multiple definition of `gpio_mode'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: multiple definition of `board_type'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/event_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: multiple definition of `module_setup'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/event_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: multiple definition of `setup_error'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/event_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: multiple definition of `gpio_direction'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/event_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: multiple definition of `pin_to_gpio'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/event_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: multiple definition of `gpio_mode'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/event_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: multiple definition of `board_type'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: multiple definition of `gpio_mode'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: multiple definition of `setup_error'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: multiple definition of `board_type'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: multiple definition of `pin_to_gpio'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:25: multiple definition of `pin_to_gpio_pc'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:25: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:24: multiple definition of `pin_to_gpio_zero2'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:24: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:27: multiple definition of `pin_to_gpio_prime'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:27: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:23: multiple definition of `pin_to_gpio_zero'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:23: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:26: multiple definition of `pin_to_gpio_pc2'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:26: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: multiple definition of `gpio_direction'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: multiple definition of `module_setup'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:29: multiple definition of `FUNCTIONS'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/boards.h:29: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:47: multiple definition of `bprime'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:47: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:46: multiple definition of `bpc2'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:46: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:45: multiple definition of `bpc'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:45: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:44: multiple definition of `bzeroplus3'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:44: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:43: multiple definition of `bzeroh5'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:43: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:42: multiple definition of `bzeroh2'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:42: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:41: multiple definition of `bunknown'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:41: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:40: multiple definition of `version'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:40: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:39: multiple definition of `soc'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:39: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:38: multiple definition of `bcm'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:38: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:37: multiple definition of `board'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:37: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:36: multiple definition of `unknown'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:36: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:35: multiple definition of `both_edge'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:35: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:34: multiple definition of `falling_edge'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:34: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:33: multiple definition of `rising_edge'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:33: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:32: multiple definition of `pud_down'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:32: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:31: multiple definition of `pud_up'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:31: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:30: multiple definition of `pud_off'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:30: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:29: multiple definition of `output'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:29: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:28: multiple definition of `input'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:28: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:27: multiple definition of `low'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:27: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:26: multiple definition of `high'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/constants.h:26: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: multiple definition of `gpio_direction'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/py_pwm.h:23: multiple definition of `PWMType'; build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/py_pwm.h:23: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: multiple definition of `module_setup'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: multiple definition of `setup_error'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: multiple definition of `pin_to_gpio'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: multiple definition of `gpio_mode'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: multiple definition of `board_type'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/soft_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/soft_pwm.c:29: multiple definition of `threads'; build/temp.linux-aarch64-3.9/source/event_gpio.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/event_gpio.c:58: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/soft_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: multiple definition of `module_setup'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:49: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/soft_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: multiple definition of `setup_error'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:48: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/soft_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: multiple definition of `gpio_direction'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:47: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/soft_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: multiple definition of `pin_to_gpio'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:45: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/soft_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: multiple definition of `gpio_mode'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:44: first defined here
/usr/bin/ld: build/temp.linux-aarch64-3.9/source/soft_pwm.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: multiple definition of `board_type'; build/temp.linux-aarch64-3.9/source/boards.o:/tmp/easy_install-zv3e7_4g/OrangePi.GPIO-0.6.3/source/common.h:43: first defined here
collect2: error: ld returned 1 exit status
error: Setup script exited with error: command '/usr/bin/aarch64-linux-gnu-gcc' failed with exit code 1
It doesn't really give me much to go on for what caused the error. The same thing happens on the Orange Pi and on a virtual environment on Ubuntu 22.04. As a test, I changed the plugin_requires variable to a random module (scrape) and the setup finished without an error. Does anyone know how to fix this error?
octoprint-systeminfo-20221213170102.zip (23.7 KB)
