I'm having trouble getting the Raise Cloud Plugin to work with multiple printers, I'm wondering if anyone might help me get it working.
I followed Chris Rileys guide to setting up multiple instances of octoprint on a single raspberry pi. I've set up three printers, each on a different instance, but the same raspberry pi. They all work with octoprint web interface just fine.
I noticed when I installed the Raise Cloud Plugin on one instance, it also installed itself on the other instances.
The plugin requires you to input a binding file from the cloud service, and although it got the first instance up and running, I am not having success binding a second printer, which appears to replace the first printer even when using a different binding code.
Would love to know your thoughts.
