I have a z stop switch acting as my filament sensor, and I'm using the Filament Sensor Reloaded plugin. I verified that it works by cutting the filament... it pauses the print, backs out the filament, and everything works fine when I reload the filament and hit resume.
All of the sudden, I have a strange problem. At approximately the same time (1-2 hours) into a print, the printer pauses for no reason. I can hit Resume and it continues printing, but eventually stops again. I can't figure out why it would be doing this.
Here are my settings for Filament Sensor Reloaded:
Here are my GCODE scripts:
Here is my SystemInfo Bundle:
octoprint-systeminfo-20211018102943.zip (761.6 KB)
Tailing the log, here is where it pauses.
2021-10-18 10:00:24,235 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:24,489 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:24,663 - octoprint.printer.standard.job - INFO - Print job paused - origin: local, path: Wood Box.aw.gcode, owner: ender, user: None
2021-10-18 10:00:24,667 - octoprint.plugins.detailedprogress - INFO - Printing paused. Detailed progress paused.
2021-10-18 10:00:24,667 - octoprint.plugins.filamentreload - INFO - PrintPaused: Disabling filament sensor.
2021-10-18 10:00:24,742 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:24,756 - octoprint.util.comm - INFO - Changing monitoring state from "Pausing" to "Paused"
2021-10-18 10:00:24,994 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:25,247 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:25,500 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:25,754 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:25,836 - octoprint.plugins.octoeverywhere - INFO - NotificationsHandler successfully sent 'paused'; ETA: 86167
2021-10-18 10:00:26,007 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:26,260 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:26,512 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:26,764 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:27,017 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:27,273 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:27,528 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:27,783 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:28,000 - octoprint.plugins.printoid - INFO - //// Send alert to Printoid: 'printer-state' with value Paused (Ender 3 v2)
2021-10-18 10:00:28,035 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:28,288 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:28,541 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:28,619 - octoprint.plugins.printoid - INFO - //// Send alert to Printoid: 'printer-state' with value Paused (Ender 3 v2)
2021-10-18 10:00:28,793 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:28,917 - octoprint.plugins.printoid - INFO - //// Send alert to Printoid: 'printer-state' with value Paused (Ender 3 v2)
2021-10-18 10:00:29,044 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:29,298 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:29,325 - octoprint.plugins.printoid - INFO - //// Send alert to Printoid: 'printer-state' with value Paused (Ender 3 v2)
2021-10-18 10:00:29,551 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:29,605 - octoprint.plugins.printoid - INFO - //// Send alert to Printoid: 'printer-state' with value Paused (Ender 3 v2)
2021-10-18 10:00:29,804 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:29,902 - octoprint.plugins.printoid - INFO - //// Send alert to Printoid: 'printer-state' with value Paused (Ender 3 v2)
2021-10-18 10:00:30,056 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
2021-10-18 10:00:30,308 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = False input = 24
