I have two errors from Octolapse for the last two prints.
I think it complains about one of the underscores in the filename.
How can I get the render, without removing the files?
plugin_octolapse.log
I can only post one screenshot as I'm a new member
foosel
March 14, 2022, 9:37am
#3
No, actually the % in the filename. Known issue, will be fixed in 1.8.0.
edit Oh wait, just saw this is Octolapse related. I don't know if it uses the stock render method, but if it does, see above, otherwise ignore me.
Is there a way for me to rename the temporary files so the render can complete?
This is also a known OctoLapse issue:
opened 04:40PM - 25 Nov 21 UTC
READ THE FOLLOWING FIRST:
I like to keep things clean. This is a place⦠for reporting bugs and
requesting new features, but is not a good place to ask questions about
or to learn how to use OctoPrint, Octolapse, or any third party programs
and tools like OctoPi, mjpg-streamer, or GPhoto2. Unfortunately there is
currently no user form dedicated to Octolapse, but you can find lots of
information directly within Octolapse (click on the blue question marks or
the help buttons within the interface), and in the Octolapse Wiki
(https://github.com/FormerLurker/Octolapse/wiki). You should also
consider submitting an issue in Octoprint Community Forms within the
plugin category (https://community.octoprint.org/c/plugins/), or via the
official OctoPrint Discord server within #support-plugins channel.
Basically, please exhaust every other option before positing an issue so I
can focus as much as possible on improving Octolapse, and fixing known
bugs. However, if you get stuck and can't find help, and you are sure your
problem isn't actually a bug, please send an email to: FormerLurker@pm.me.
For feature requests, add the prefix "[Request]" in the title (without the
quotes).
Do not delete anything from the template except where noted or the
bot will complain.
Thanks!
#### If this is a feature request describe it here
Please be as clear as possible. After you are finished, please fill in the
OctoPrint and Octolapse version. Maybe the feature already exists?
___REPLACE_THIS__FEATURE_REQUEST_DESCRIPTION_GOES_HERE
#### Version of Octolapse
This can be found within the Octolapse settings in the About tab.
If you suspect an installation issue from the plugin manager,
please state that here, especially if you are installing a specific
branch, and not the default (master) branch.
DO NOT OMIT
Octolapse Version: ___REPLACE_THIS__OCTOLAPSE_VERSION_GOES_HERE
#### Version of OctoPrint
Can be found in the lower left corner of the web interface.
DO NOT OMIT
OctoPrint Version: 1.7.2
If this is a feature request, you are done! Thanks!
If not, please continue
#### When you ran into the problem, did you have diagnostic logging enabled?
You can find out more about diagnostic logging here:
https://github.com/FormerLurker/Octolapse/wiki/Debug-Profiles#log-additional-information
It is very helpful for certain problems. If you can reproduce the issue with
one of the Diagnostic logging profiles, please do so before submitting an issue.
Diagnostic Logging was Enabled: YES
#### What were you doing when the problem occurred
Be specific. Explain what you did as clearly as possible.
It's best if you provide a list of steps you took that can
be used to reproduce the error you encountered.
1. After the print completed I clicked on the button for unfinished rendering
2. Clicked on the render with selected settings video button
3. Changing settings continued to cause the error
I recently updated my octoprint build on my system. Prior to the update my rendered timelapse videos were always available to download in completed timelapses. I did make sure to turn on Verbose G-code in PrusaSlicer.
#### What should have happened?
I expected to download the rendered video
#### What happened instead?
Rendering failed for camera 'Webcam - Default OctoPi 0.16.0'. render-error: Unknown render error. Please check plugin_octolapse.log for more details.. Inner Exception: unsupported format character '_' (0x5f) at index 37
#### Operating System running OctoPrint and Octolapse
OctoPi, Linux, Windows, MacOS, something else?
Include the version number if possible.
OctoPi's version can be found in /etc/octopi_version or in the lower left
DO NOT OMIT
OS Name: Windows
Os Version: 10 64 bit
#### Printer model & used firmware incl. version
OMIT ONLY IF IT IS DEFINITELY NOT NEEDED.
Printer Model: Prusa mk3s+
Printer Firmware Version: 3.9.2-3524
#### Browser and version of browser, operating system running browser
Browser: Chrome
Browser OS: 96.0.4664.45 (Official Build) (64-bit)
#### Link to the gcode file you were printing when the problem occurred
Many problems I've seen are due to specific gcode files.
Sometimes it's a bug, sometimes it can be slicer settings,
other times it can be Octolapse or OctoPrint setting related.
In any case, the gcode file is often very useful.
On gist.github.com or pastebin.com.
Link to Gcode File: (https://gist.github.com/ShamusTheTinker/53b66cfb7530a3a06381223efc3e632d)
#### Link to settings.json
Lots of problems are settings related, and having them available
makes debugging a lot easier. You can export the settings.json
file from within the Octoprint settings.
BE AWARE - IF YOU HAVE ANY PASSWORDS IN YOUR CAMERA PROFILE,
THEY WILL BE EXPORTED ALONG WITH THE REST OF YOUR SETTINGS!
IF YOU ARE USING CAMERA AUTHENTICATION IN ANY OF YOUR PROFILES,
EITHER REMOVE THE PASSWORDS BEFORE EXPORTING, DELETE THEM FROM THE FILE
AFTER EXPORTING, OR DON'T POST SETTINGS.JSON! You can search for
"password":
to find all of the entries containing passwords.
OMIT ONLY IF YOU HAVE ENTERED A PASSWORD TO ACCESS YOUR CAMERA
WITHIN OCTOLAPSE
Link to settings.json with all passwords removed: (https://gist.github.com/ShamusTheTinker/19a866393459dee0ce3411f9802c1690)
#### Link to plugin_octolapse.log
DO NOT OMIT IF YOU ARE USING OCTOLAPSE V0.2.2 OR LATER.
IF YOU ARE USING V0.2.1 OR EARLIER DO NOT POST YOUR LOGFILE
SINCE IT MAY CONTAIN CAMERA AUTHENTICATION PASSWORDS IF THEY WERE
ENTERED.
Link to plugin_octolapse.log: https://gist.github.com/ShamusTheTinker/9e22d69f4b652675a5c80fcf14696892
#### Link to octoprint.log
DO NOT OMIT
Link to octoprint.log: https://gist.github.com/ShamusTheTinker/0881815bd9e3e8727ad753c659111f72
#### Link to contents of Javascript console in the browser
If you are having UI problems, like buttons not working, or problems saving
settings, please inlude the javascript console output
on gist.github.com or pastebin.com.
Link to javascript console output: ___REPLACE_THIS__LINK_GOES_HERE
#### Screenshots and/or videos of the problem:
This is really nice to include, especially if you're having trouble
putting your issue into words. A picture speaks 1000 of them, afterall!
Screenshot/Video Links: ___REPLACE_THIS__LINKs_GO_HERE
## Please consider becoming a patron
If you like this project, [please support my work by becoming a patron,](https://www.patreon.com/bePatron?u=9588101) and consider adding a 'star' to the repository. It takes a lot of time and effort to maintain the project and respond to issues. The cost of test prints, software, cameras, printer parts, etc. can quickly add up, so every bit helps.
You can find various [videos and tutorials](https://www.youtube.com/channel/UCnnTLQetNw7FqfQOLJCMqoQ) by subscribing to my Youtube channel. You can also [follow me on Twitter](https://twitter.com/FormerLurker1).
You can upgrade to patched version in the issue to render it.
That worked, thanks!
EDIT: Actually, the rendering worked now, but downloading doesn't.
The forth in the list below does work.
It's because of the + signs:
