Yes, screen -L will start a "new" terminal window. From this point on, it is logging the terminal inputs and outputs to the file screenlog.0 (unless you gave it a different name on the screen command line). When you type exit, the screenlog.0 file will be closed and you will be back to your original terminal window. You can then do something with the screenlog.0 file like post it here (using the </> button above).
The WARNING: Filesystem still has errors just confirms what we already know about this SD disk, it is corrupted. It doesn't look like we are going to get anything useful off of that disk.
As to the fsck error need terminal for interactive repairs, there is probably a switch that will eliminate that error, but I don't know what it is ATM.
fred41
October 16, 2020, 12:47am
22
ok, thanks again for the help.
I think I managed to copy the files, I should have all the home folder
I tried looking in logs home\pi.octoprint\logs\octoprint.log but I didn't find my plugin listed ...
Is there a way I could find at least a list of my plugin?
last time I ask for help, if I cant find it, I will install a new octopi with a new sd card, it will be quicker.
agreed.
Post the octoprint.log somewhere, and we can have a look.
fred41
October 16, 2020, 1:07pm
24
here is my .octoprint folder and the log alone.
It doesn't look like you had any non-bundled plugins installed:
2020-10-14 21:36:26,432 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
fred41
October 16, 2020, 2:11pm
26
ok, my mistake, I was looking in new pi folder, not the old mount in mnt/
Sorry, here is my log, where I can find my plugins
2020-10-11 22:57:36,730 - octoprint.plugin.core - INFO - 42 plugin(s) registered with the system:
| !Access Anywhere - The Spaghetti Detective (1.4.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_thespaghettidetective
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
| Autoscroll (0.0.3) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_autoscroll
| Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
| Backup Scheduler (0.0.3) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_backupscheduler
| Bed Visualizer (0.1.15) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_bedlevelvisualizer
| Cancel Objects (0.4.4) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_cancelobject
| !Consolidated Tabs (0.1.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_consolidatedtabs
| Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
| !Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
| DisplayZ (0.2.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_displayz
| !Dragon Order (0.1.6) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_dragon_order
| Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
| File Check (2020.8.7) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
| Firmware Check (2020.9.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
| Floating Navbar (0.3.4) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_floatingnavbar
| Fullscreen Plugin (0.0.5) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_fullscreen
| GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
| Google Drive Backup (0.0.3) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_googledrivebackup
| Heatbedsavety (0.1.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_heatbedsavety
| Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
| Login UI (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/loginui
| Multi Colors (1.0.17) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_multi_colors
| MultiCam (0.2.8) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_multicam
| Navbar Temperature Plugin (0.14) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_navbartemp
| *OctoPrint-DetailedProgress (0.2.5) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_detailedprogress
| Pi Support Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
| *Printer Stats (2.0.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_stats
| PrintTimeGenius Plugin (2.2.6) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius
| Procastinator (1.1.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_procastinator
| Sidebar Webcam (0.1.8) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_webcamSB
| Simple Emergency Stop (1.0.3) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_simpleemergencystop
| Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
| Tab Order (0.5.11) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_taborder
| Themeify (1.2.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_themeify
| *Tuya Smartplug (0.2.3) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_tuyasmartplug
| Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
So out of these, the non-bundled, non-disabled, non-incompatible plugins you had installed are:
Autoscroll (0.0.3)
DisplayZ (0.2.0)
MultiCam (0.2.8)
Tab Order (0.5.11)
Themeify (1.2.2)
