Nils
February 25, 2022, 7:44am
1
did not find anything in the documentation and also failed searching in the code.... is it possible to trigger the restart required command also from the plugin itself? I need it to request a restart if a configuration is changed...
Cheers,
Nils
OctoPrint.system.executeCommand("core", "restart"); will do the command, an example of it being called from plugin manager (which is a plugin).
showConfirmationDialog({
message: gettext(
"<strong>This will restart your OctoPrint server.</strong></p><p>This action may disrupt any ongoing print jobs (depending on your printer's controller and general setup that might also apply to prints run directly from your printer's internal storage)."
onproceed: function () {
OctoPrint.system
.done(function () {
notice.remove();
new PNotify({
title: gettext(
"Restart in progress"
text: gettext(
"The server is now being restarted in the background"
.fail(function () {
new PNotify({
This file has been truncated. show original
