I use Octoprint for quite some time, also for more than a year with my SnapMaker A350 (Footnote: an updated SnapMaker plugin would be nice).
While printing with a single extruder, everything is fine.
When doing a print that actually uses both extruders of my new dual extrusion head, I run into a problem.
1st workflow: Use the slicer that comes with the Snapmaker (Luban, wich relies on the cura slicer), export the gcode directly into the machine, start. Printing is done properly using both extruders.
2nd workflow: Same model, same slicer, but export to gcode file. Upload gcode file to Octoprint, which in turn sends the gcode to the machine. Result: Only the first extruder is used, no switching takes place.
Conclusion: Octoprint either takes out, ignores or gobbles the necessary gcode to switch the extruders.
Questions: Has anybody else run into this as well? Has anybody solved the problem already?
Regards
pah
