Is it currently possible to get the version number of a plugin via a REST call?
I can query whether a plugin is present via http://octopi.local/api/settings/templates, but I'd like to find out (via REST) the version number of a specific plugin. Is this possible? (I searched the API doc but didn't see anything)
Thanks @jneilliii, that was perfect! Odd, I read through the docs at https://docs.octoprint.org/en/master/api but didn't see any mention of this. If this is an unpublished/udocumented API, how stable is it (eg is it likely to change)?
It's probably not documented because it's part of the plugin manager plugin. If it is documented it would be under that section in the docs. I would think it will be there for a while because it's what the plugin manager uses to pull the official repo and know what's installed. Since it is used for that I believe it's extremely stable.
