Hi There
I know there are two Plugins for automatic shutdown:
And there is my own python script, signal.py. Now I would like to run this script together with one of the plugins but which one is the best for the job and how?
Thank you
Hi There
Thank you
hello
I've same concerns
please help
You guys can do this without a plugin. You just need to setup the script to run in config.yaml events section.
https://docs.octoprint.org/en/master/configuration/config_yaml.html#events
More than likely you don't have any there now so you would have to add the whole section.
events:
subscriptions:
- event: Shutdown
command: "/full/path/to/script.py'"
type: system
