Set simulation speed for the Virtual printer
Looking at http://docs.octoprint.org/en/master/configuration/config_yaml.html#development-settings
There is the possibility to set the speed of simulation? For example, I have a very small object which I use to simulate printing using the virtual printer bundled in OctoPrint, but the simulation speed is too fast.
I would like to know if there is a way to slow down the simulation process. It is also good to wait for example 5 seconds after each layer; this is just an example.
Hi @cristiano-c,
you could slow down the print with your slicer, also insert a pause every layer.
