I´m struggling with Knockout and some user elements in my OctoPrint plugin. I want to add a user button to the settings menu entry of my plugin, but I don´t get any debug output in my browser when I click the button:
SpoolScale_settings.jinja2
<div class="control-group">
<div class="controls">
<button class="btn" type="button" data-bind="click: Test">Test</button>
</div>
</div>
SpoolScale.js
$(function()
function SpoolscaleViewModel(parameters)
var self = this;
self.Weight = ko.observable();
self.onDataUpdaterPluginMessage = function(plugin, data)
if((plugin != "SpoolScale") || (!data))
return;
console.log("Update");
if(data.Weight)
self.Weight("Weight: " + data.Weight);
self.onBeforeBinding = function()
console.log("Before binding");
self.Test = function()
console.log("Test");
OCTOPRINT_VIEWMODELS.push({
construct: SpoolscaleViewModel,
dependencies: [ "settingsViewModel" ],
elements: [ "#navbar_plugin_SpoolScale", "#settings_plugin_SpoolScale" ]
My variable "Weight" from my navbar gets updated all the time (the value is delivered by init.py).
SpoolScale_navbar.jinja2
<div class="navbar-text">
<span id="weight" data-bind="text: Weight"></span> g
</div>
init.py
class SpoolscalePlugin(octoprint.plugin.StartupPlugin,
octoprint.plugin.AssetPlugin,
octoprint.plugin.TemplatePlugin,
octoprint.plugin.SettingsPlugin):
def __init__(self):
self.__Settings = dict()
self.__Settings["DOUT"] = 17
self.__Settings["SCK"] = 4
self.__Settings["Weight"] = 4.32
self.__HX = HX711.HX711(DOUT = int(self.__Settings["DOUT"]), SCK = int(self.__Settings["SCK"]))
def __StartTimer(self):
self.__UpdateTimer = RepeatedTimer(1, self.on_Timer, run_first = True)
self.__UpdateTimer.start()
def on_Timer(self):
self._plugin_manager.send_plugin_message(self._identifier,
dict(Weight = int(random() * 100))
def on_after_startup(self):
self._logger.info("Version: {}")
self.__StartTimer()
def on_shutdown(self):
if(self.__HX):
del self.__HX
def on_settings_save(self, data):
def get_template_configs(self):
return [
dict(type = "navbar", custom_bindings = False),
dict(type = "settings", custom_bindings = False)
def get_settings_defaults(self):
return self.__Settings
def get_assets(self):
return {
"js": ["js/SpoolScale.js"],
"css": ["css/SpoolScale.css"],
"less": ["less/SpoolScale.less"]
def get_update_information(self):
return {
"SpoolScale": {
"displayName": "Spoolscale Plugin",
"displayVersion": self._plugin_version,
# version check: github repository
"type": "github_release",
"user": "kampi",
"repo": "OctoPrint-Spoolscale",
"current": self._plugin_version,
# update method: pip
"pip": "https://github.com/kampi/OctoPrint-Spoolscale/archive/{target_version}.zip",
__plugin_name__ = "Spool Scale"
__plugin_pythoncompat__ = ">3,<4"
def __plugin_load__():
global __plugin_implementation__
__plugin_implementation__ = SpoolscalePlugin()
global __plugin_hooks__
__plugin_hooks__ = {
"octoprint.plugin.softwareupdate.check_config": __plugin_implementation__.get_update_information
What is the reason why the update of the navbar is working as expected, but the button from the settings menu isn´t working? I don´t get it...
