error: subprocess-exited-with-error
× Getting requirements to build wheel did not run successfully.
│ exit code: 255
╰─> [1 lines of output]
Could not import OctoPrint's setuptools, are you sure you are running that under the same python installation that OctoPrint is installed under?
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
│ exit code: 255
╰─> See above for output.
RROR: You must give at least one requirement to wheel (see "pip help wheel")
reinstall python venv, doublechecked octoprints venv
no
matter?
octoprint-systeminfo-20230423165422.zip (9,6 KB)
HW: odroid C4
OS: ubuntu 22-04 mini (opdated odroid image)
Installation: manual, depending to octoprints doc
User; odroid
venv: Python 3.10.7 ~/oprint
Octoprint Insallation succeeded without any errors
Octoprint startup looks fine also no errors
But I'm not able to install octoklipper after OP base installation.
klipper itself is also installed and up without any errors, of course from its own venv
