I'm having an issue with this plugin: Octoprint-Filament-Reloaded-OrangePi
The board is an orange pi zero plus (H5) Armbian:
pi@octo:~$ uname -a
Linux octo 4.14.65-sunxi64 #6 SMP Mon Aug 20 20:01:45 CEST 2018 aarch64 GNU/Linux
The following error appears in the log:
"IOError: [Errno 13] Permission denied: '/sys/class/gpio/gpio14/direction'"
The plugin appears to set up the pin correctly via:
pi@octo:~$ cat /sys/class/gpio/gpio14/direction
in
ls -al /sys/class/gpio/
-rwxrwx--- 1 root gpio 4096 Aug 27 20:07 export
lrwxrwxrwx 1 root root 0 Aug 27 20:16 gpio14 -> ../../devices/platform/soc/1c20800.pinctrl/gpiochip1/gpio/gpio14
lrwxrwxrwx 1 root root 0 Dec 31 1969 gpiochip0 -> ../../devices/platform/soc/1c20800.pinctrl/gpio/gpiochip0
lrwxrwxrwx 1 root root 0 Dec 31 1969 gpiochip352 -> ../../devices/platform/soc/1f02c00.pinctrl/gpio/gpiochip352
-rwxrwx--- 1 root gpio 4096 Aug 27 19:55 unexport
The gpio permissions seem to be proper; I can do the following as pi user (without sudo):
pi@octo:~$ echo out | tee /sys/class/gpio/gpio14/direction
out
pi@octo:~$ echo in | tee /sys/class/gpio/gpio14/direction
in
As pi user, I can:
out
pi@octo:~$ echo 0 > /sys/class/gpio/gpio14/value
pi@octo:~$ cat /sys/class/gpio/gpio14/value
0
pi@octo:~$ echo 1 > /sys/class/gpio/gpio14/value
1
Seems to be an issue with the plugin.
Thanks for your feedback.
since the OPI gpio library is really bad ... the only way to make it work is to add the delay so to avoid the race condition with the file and udev systems .. I was hoping that either that library will fix itself or that armbian will somehow fix itself or whatever but didn't want to make fork of the lib myself as I'm really not a python dev so it makes zero sense.. I run this plugin on my computers with the same "delay" hack in the lib
