if you look at the readme on the github of that plugin the issue is with the opi gpio library that had a race condition, here used to be a patch for that library that would allow it to properly work, but recently they fixed the library so if you have latest gpio library it will work ok ...
so from the readme:
OrangePI OS Configuration
Since we are accessing the GPIO as a non root user we need to configure the OS to allow this. Here's the copy of the library documentation on how to do it:
If you want to be able to use the library as a non root user, you will need to setup a UDEV rule to grant you permissions first.
This can be accomplished as follows:
press ctrl-x, Y, and ENTER to save and close the file.
Finally, reboot and you should be ready to use OPi.GPIO as a non root user.
Issues with OPI GPIO library
https://github.com/rm-hull/OPi.GPIO/pull/28 solves the issues with PI GPIO library and the race condition that was preventing normal operations. It is available in release v0.3.4 and up so make sure you have latest OPI GPIO library. To upgrade to latest OPI GPIO library login to your octoprint server as user pi and execute:
$ cd OctoPrint/
$ venv/bin/pip install --upgrade OPi.GPIO
