I'm trying to write an Android app to access the OctoPrint API. My problem is that I always get a HTML request - not JSON.
My code
Uri.Builder builder = new Uri.Builder( );
builder.scheme( "http" );
builder.encodedAuthority( "172.16.0.150:5000" );
builder.appendQueryParameter( "/api/version", "" );
builder.appendQueryParameter( "HTTP/1.1", "" );
builder.appendQueryParameter( "X-Api-Key", "<redacted>" );
Uri uri = builder.build( );
Log.e( "###", "uri =" + uri.toString( ) + "=" );
URL url = new URL( uri.toString( ));
HttpURLConnection connection =(HttpURLConnection) url.openConnection( );
connection.setRequestProperty("Accept", "application/json");
connection.setRequestMethod( "GET" );
connection.connect( );
InputStreamReader streamReader = new InputStreamReader( connection.getInputStream( ));
BufferedReader reader = new BufferedReader( streamReader );
StringBuilder stringBuilder = new StringBuilder( );
String inputLine;
while( (inputLine = reader.readLine( )) != null )
stringBuilder.append( inputLine );
reader.close( );
streamReader.close( );
String jsonText = stringBuilder.toString( );
Log.e( "###", "jsonText =" + jsonText );
HELP!
This is incorrect - these are not query parameters as I understand them.
The first is the API endpoint, so you likely want to use builder.appendPath("/api/version") instead.
The second, the HTTP/1.1 part, is not a parameter either, and I'm not sure why you have included it in the request. Unless I am missing something, this is implied by the builder.scheme("http").
Thank you for your reply. I'll give the "appendPath" a try tomorrow.
As for the "HTTP/1.1" - I was trying, quite literally, everything.
FWIW, this is what works:
builder.encodedAuthority( "172.16.0.150:5000/api/version" );
HttpURLConnection httpConnection =(HttpURLConnection) url.openConnection( );
httpConnection.setRequestProperty("Accept", "application/json");
httpConnection.setRequestProperty( "X-Api-Key", "<redacted>");
httpConnection.setRequestMethod( "GET" );
httpConnection.connect( );
InputStreamReader streamReader = new InputStreamReader( httpConnection.getInputStream( ));
String inputLine;
reader.close( );
