SSD Card is buried in the printer. Is there a way to view all files on the card via SSH
Way to many files, Total files on SSD should be about 8gb but its nearly 54gb. Cant easily access the SSD to check for other files.
Not sure where to start. Ive tried looking up a way to SSH into the root to see whats on the SSD
NA
Prusa MK3s Newest Octopi install on a Pi Zero 2 W running right off the ENSY board of the printer. All software is newest release for printer and Octoprint.
My PI is buried in the printer so its hard to get access to the SSD without taking apart the printer. I just updated Octoprint with a 64GB card I used my backup to reinstall all my plugins and get back online but the backup is about 8gb. However Octoprint says it only has 1.1gb Free out of 58.3GB. So its either reading the info wrong or there are other files on the card.
Is there a way to check via SSH?
If you are able to SSH into the device, you can for sure look at the contents of the ssd/sd card.
I would also suggest that you look to see if maybe your log files are big. You can review and delete them.
Also if you cloned your old ssd/sd card, to the new larger one, likely it was formatted the same size as the old one so you really did not get more space by doing that.
If you end up pulling things apart, it might be good to install one of these to make your life easier in the future.
sd card:
https://www.amazon.com/Extension-Adapter-Compatible-Flexible-Extender/dp/B0D7Z7Y3LZ
ssd:
https://www.amazon.com/Sintech-M-Key-Extention-Cable-20CMS/dp/B07DZCCGJN
