It would be nice to be able to add a small note on a print in the files list. Just an icon to the left of print/download/delete/etc.
Very often I don't remember what each print is just by the name, if I could add a note I would write some small description to the print. Then the note could be showed on the "additional data" area.
thanks a lot
Edit: With Octoprint Connection plugin (Cura) and Ultimaker Format Package plugin I have screenshots on the file list. It's perfectly and helps me know what is the print.
What slicer are you using?
For PrusaSlicer there is this solution:
And for Cura this:
S3D will also use PrusaSlicer with the relevant post processing.
Master is Linux only with S3D picture.
Openscad Branch also does openscad thumbs and Mac Support
Master Linux
+openscad & Mac
Hopefully they will be merged at some point. And if someone wants to add windows support I am sure NotExpectedYet will appreciate it......
(Oops that was meant to be a reply to all)
I use Cura, nice plugin, I'll try it, thanks a lot!
Yeah, the combination of my UltimakerFormatPackage plugin and @fieldOfView's OctoPrint Connection plugin for Cura are a sweet combination...
Maybe I am wrong, but what @Drake_Coldwinter is looking for doesn't exists 100%.
As an alternative you can use StickyPad or PrintJobHistory to take notes to a PrintJob.
I (Edit: Typo) think the thumbnail suggestion was aimed at the remember what the job was, a visual reminder. Of cause as printjob can also using thumbnails as well that is the perfect.
Personally I use S3d with prusa thumbs, prusa thumbs and printjob plugin notes feature. Perfect.
I had already the Octoprint connection plugin. Now with the UFP plugin I have screenshots with fulfil my purpose perfectly
Very happy, thanks a lot.
Awesome, glad my plugin worked out for you.
