While I applaud the support, it does get in the way of making replies. I suggest moving it some place else, please. Almost any other corner would be better. If I was in charge, the two tone green wave in the upper left would change colors.
tentacle, but yeah think it needs adjusting. doesn't effect me as much on widescreen monitor but noticed at work it covered the buttons.
As a workaround: You can make the Edit window smaller by using the arrows bottom right.
Depends on the size of your screen/monitor.
I'll look into it
Modding the style to use z-index = 10 seems to work.
Temporarily disabled again, will see whether I'll use the z-index or some other solution tomorrow (it's 11pm here and I'm exhausted), but some kind of support expression will be back here as well.
Replaced with a top banner. Haven't yet found a way to make it stay like the nav bar, but it's there at least. Thanks for the heads-up regarding the UX issues with the reply form, appreciated!
