Hello together!
I am new in the 3D Printing World and have installed OctoPi via your Image on my RPi 3b.
Then i have installed the Plugin System Command Editor.
And if i try to execute sudo ~/433Utils/RPi_utils/codesend MYCODE
i got an Error:
Command for custom:Licht aus failed with return code 1:
STDOUT:
STDERR: sudo: no tty present and no askpass program specified
How can i fix this?
Sry for my Bad English, i am a German User with terrible English skills...
I follwed this Tutorial:
Best Regards
Did you try to send the command directly in the raspberry-terminal (via ssh)?
Please post a screenshot of your command-settings.
Cy,
Olli
You might need to remove requiretty from the sudoers configuration. This could possibly be:
Update: ignore this part
sudo nano /etc/sudoers
# Add the line in the header:
Defaults:pi !requiretty
I'm not sure because I've never run this plugin and this hardware that you have.
It's also possible that you just simply need to add a file:
sudo touch /etc/sudoers.d/codesend
sudo nano /etc/sudoers.d/codesend
# Here is the content:
pi ALL=(ALL) NOPASSWD: /home/pi/433Utils/RPi_utils/codesend
Good Morning!
@OllisGit
Yes i have done this, and there it will be OK! It works without Errors...
Here is a Screenshot:
http://abload.de/image.php?img=unbenannt5ikuf.jpg
@ OutsourcedGuru
Thanks! I will try this, and give you feedback!
Best Regards
Hello again!
@OutsourcedGuru
You are my hero!
The Line in the sudoers File has not worked, BUT then i have created a File with
With the follwing content:
After a Reboot the command works like a charme!
Thank you very much, for your fast help!
Have a nice Day
Best Regards
